[postgis-tickets] [PostGIS] #5446: 3.4.0-beta1 fails to build (unable to parse postgis-out.xml)
PostGIS trac at osgeo.org
Sat Jul 15 04:10:55 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 That address_standardizer_required.tag file is clearly corrupted in your
 build.
 It's generated by xmllint which is known to be not always returning the
 correct exit code (exits with SUCCESS even if it fails).
 What's the exact top-level command that you are issuing after configure ?
 Can you consistently reproduce ?
 I'm not being able to reproduce with a loop under the doc/ dir:
 while :; do make -j clean && make -j8  || break; done
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5446#comment:3>
