[postgis-tickets] [PostGIS] #5446: 3.4.0-beta1 fails to build (unable to parse postgis-out.xml)
PostGIS trac at osgeo.org
Sat Jul 15 04:25:32 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Bas Couwenberg):
 > What's the exact top-level command that you are issuing after configure
 $(MAKE) $(NJOBS) -C doc
 See: https://salsa.debian.org/debian-gis-
 team/postgis/-/blob/master/debian/rules#L139
 Which translates to:
 /usr/bin/make -j3 -C doc
 > Can you consistently reproduce ?
 No, as mentioned in comment:2.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5446#comment:4>
