[postgis-tickets] [PostGIS] #5446: 3.4.0-beta1 fails to build (unable to parse postgis-out.xml)
PostGIS trac at osgeo.org
Sat Jul 15 04:37:33 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 Sorry I meant if you could reprodce at all.
 The very first top-level command is {{{ $(MAKE) $(NJOBS) }}} if I read
 correctly.
 That one alone should in turn build the comments under doc, are you sure
 you need the subsequent {{{ -C doc }}} ? Not that it matters for this bug
 report, but I'm wondering what I'm missing
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5446#comment:5>
