[postgis-tickets] [PostGIS] #5446: 3.4.0-beta1 fails to build (unable to parse postgis-out.xml)
PostGIS trac at osgeo.org
Sat Jul 15 07:11:52 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Bas Couwenberg):
 The issue was encountered 3 out of 6 times that the package was built in
 clean chroots, the interactive sessions I started in another chroot didn't
 trigger the issue.
 The CI builds also haven't triggered the issue.
 We are seeing a different dependency issue on the
 [https://buildd.debian.org/status/package.php?p=postgis&suite=experimental
 buildds]:
 mkdir -p /<<PKGBUILDDIR>>/debian/tmp/usr/share/doc/images
 /usr/bin/install -c -m 644 de9im01.png de9im02.png st_alphashape01.png
 /<<PKGBUILDDIR>>/debian/tmp/usr/share/doc/images/
 /usr/bin/install: cannot stat 'st_buildarea01.png': No such file or
 directory
 /usr/bin/install: cannot stat 'st_letters01.png': No such file or
 directory
 make[3]: *** [Makefile:242: images-install] Error 1
 Full buildlogs:
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=all&ver=3.4.0%7Ebeta1%2Bdfsg-1%7Eexp1&stamp=1689429448&raw=0
 all],
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=s390x&ver=3.4.0%7Ebeta1%2Bdfsg-1%7Eexp1&stamp=1689429572&raw=0
 s390x],
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=hppa&ver=3.4.0%7Ebeta1%2Bdfsg-1%7Eexp1&stamp=1689427938&raw=0
 hppa],
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=m68k&ver=3.4.0%7Ebeta1%2Bdfsg-1%7Eexp1&stamp=1689428947&raw=0
 m68k]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5446#comment:7>
