[postgis-tickets] [PostGIS] #5446: 3.4.0-beta1 fails to build (unable to parse postgis-out.xml)
PostGIS trac at osgeo.org
Sat Jul 15 08:37:38 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 From the all logs I see:
 configure was unable to find 'xmllint' which is required
 warning: failed to load external entity "sfs_compliant.tag"
 xmllint is a new dependency, now needed to create those "tag" files. It's
 a way to extract a tag from an xpath. The Makefile is not protecting from
 lack of it in a proper way, I'm afraid.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5446#comment:8>
