[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-7-g9908e9098
Sat Jul 15 08:43:26 PDT 2023
the project "PostGIS".
       via  9908e9098acc89184f1ba728114387301f36550c (commit)
      from  8a2c14d611958b7ca1fe8549f10a20325411db14 (commit)
revisions in full, below.
commit 9908e9098acc89184f1ba728114387301f36550c
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Jul 15 17:42:57 2023 +0200
    Fail if xmllint is not found
    References #5446
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 4e75f5f0b..36649dd30 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -585,16 +585,18 @@ requirements_not_met_xsltproc:
 	@echo
 	@echo "  http://postgis.net/documentation"
 	@echo
+	@false
 requirements_not_met_xmllint:
 	@echo
 	@echo "configure was unable to find 'xmllint' which is required"
-	@echo "to test the documentation."
+	@echo "to build the documentation."
 	@echo "Install xmllint and then re-run configure. Alternatively "
 	@echo "refer to online manual:"
 	@echo
 	@echo
+	@false
 requirements_not_met_xslbase:
 	@echo
Summary of changes:
 doc/Makefile.in | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
hooks/post-receive
