[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-8-gd81ed3840
Sat Jul 15 09:43:44 PDT 2023
the project "PostGIS".
       via  d81ed384088daf42186c035b09d63128d67171f3 (commit)
      from  9908e9098acc89184f1ba728114387301f36550c (commit)
revisions in full, below.
commit d81ed384088daf42186c035b09d63128d67171f3
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Jul 15 18:30:20 2023 +0200
    Drop xmllint requirement for extracting tags
    References #5446
    Fail if tag nodes cannot be extracted from xsl-config
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 36649dd30..241559351 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -300,13 +300,13 @@ $(XSL_GENERATED_SOURCES): %.xsl.xml: xsl/%.xml.xsl postgis-nospecial.xml xsl-con
 	$(XSLTPROC) --novalid $(XSLTPROC_PATH_OPT) -o $@ $< postgis-nospecial.xml
 endif
-ifeq ($(XMLLINT),)
-$(TAG_GENERATED_SOURCES): requirements_not_met_xmllint
+ifeq ($(XSLTPROC),)
+$(TAG_GENERATED_SOURCES): requirements_not_met_xsltproc
 else
-$(TAG_GENERATED_SOURCES): xsl-config.xml Makefile
+$(TAG_GENERATED_SOURCES): xsl/node_by_xpath.xsl xsl-config.xml Makefile
 	tag=tag_$(basename $(notdir $@)); \
-	$(XMLLINT) --xpath "/config/tags/para[@role='$$tag']/node()" $< > $@.tmp && \
-	mv $@.tmp $@
+	$(XSLTPROC) --stringparam xpath "/config/tags/para[@role='$$tag']" -o $@ $< xsl-config.xml
+	test -s $@ # ensure something was extracted
 endif
 $(GENERATED_COMMENT_FILES): %.sql: xsl/%.sql.xsl $(XML_INPUTS) postgis-out.xml
diff --git a/doc/xsl/node_by_xpath.xsl b/doc/xsl/node_by_xpath.xsl
new file mode 100644
index 000000000..f26fc37d1
--- /dev/null
+++ b/doc/xsl/node_by_xpath.xsl
@@ -0,0 +1,23 @@
+<?xml version="1.0"?>
+Example usage:
+	xsltproc \
+		-stringparam pattern "/config/tags/para[@role='tag_P_support']"
+		-stringparam value '.' xsl/extract_xpath.xsl
+		xsl-config.xml
+<xsl:stylesheet
+	xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0"
+	xmlns:dyn="http://exslt.org/dynamic" extension-element-prefixes="dyn"
+  <xsl:output method="xml" omit-xml-declaration="yes" indent="no" />
+  <xsl:template match="/">
+    <xsl:for-each select="dyn:evaluate($xpath)">
+      <xsl:copy-of select="." />
+    </xsl:for-each>
+  </xsl:template>
+</xsl:stylesheet>
Summary of changes:
 doc/Makefile.in           | 10 +++++-----
 doc/xsl/node_by_xpath.xsl | 23 +++++++++++++++++++++++
 2 files changed, 28 insertions(+), 5 deletions(-)
 create mode 100644 doc/xsl/node_by_xpath.xsl
hooks/post-receive
