[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-9-g721c37c11
Sat Jul 15 09:52:18 PDT 2023
the project "PostGIS".
       via  721c37c116c3604e5da676b105048725ad2e226c (commit)
      from  d81ed384088daf42186c035b09d63128d67171f3 (commit)
revisions in full, below.
commit 721c37c116c3604e5da676b105048725ad2e226c
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Jul 15 18:51:16 2023 +0200
    Fix out-of-tree build
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 241559351..aea12dcb1 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -303,9 +303,9 @@ endif
 ifeq ($(XSLTPROC),)
 $(TAG_GENERATED_SOURCES): requirements_not_met_xsltproc
 else
-$(TAG_GENERATED_SOURCES): xsl/node_by_xpath.xsl xsl-config.xml Makefile
+$(TAG_GENERATED_SOURCES): xsl/node_by_xpath.xsl xsl-config.xml | Makefile
 	tag=tag_$(basename $(notdir $@)); \
-	$(XSLTPROC) --stringparam xpath "/config/tags/para[@role='$$tag']" -o $@ $< xsl-config.xml
+	$(XSLTPROC) --stringparam xpath "/config/tags/para[@role='$$tag']" -o $@ $^
 	test -s $@ # ensure something was extracted
 endif
Summary of changes:
 doc/Makefile.in | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
