[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-10-g69754edb0
Sat Jul 15 09:56:22 PDT 2023
the project "PostGIS".
       via  69754edb0785956854c7114b095b7b08356b7acc (commit)
      from  721c37c116c3604e5da676b105048725ad2e226c (commit)
revisions in full, below.
commit 69754edb0785956854c7114b095b7b08356b7acc
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Jul 15 18:55:39 2023 +0200
    Update usage comment
diff --git a/doc/xsl/node_by_xpath.xsl b/doc/xsl/node_by_xpath.xsl
index f26fc37d1..928cfdb42 100644
--- a/doc/xsl/node_by_xpath.xsl
+++ b/doc/xsl/node_by_xpath.xsl
@@ -1,10 +1,10 @@
 <?xml version="1.0"?>
-Example usage:
+Example usage (replace the single dash with two dashes):
 	xsltproc \
-		-stringparam pattern "/config/tags/para[@role='tag_P_support']"
-		-stringparam value '.' xsl/extract_xpath.xsl
+		-stringparam xpath "/config/tags/para[@role='tag_P_support']"
 		xsl-config.xml
Summary of changes:
 doc/xsl/node_by_xpath.xsl | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
