[postgis-tickets] [PostGIS] #5446: 3.4.0-beta1 fails to build (unable to parse postgis-out.xml)
PostGIS trac at osgeo.org
Sat Jul 15 10:15:05 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Bas Couwenberg):
 I've just uploaded a new revision with libxml2-utils added to the build
 dependencies:
  https://salsa.debian.org/debian-gis-
 team/postgis/-/commits/debian/3.4.0_beta1+dfsg-1_exp2?ref_type=tags
 The s390x still fails the same:
 mkdir -p /<<PKGBUILDDIR>>/debian/tmp/usr/share/doc/images
 /usr/bin/install -c -m 644 de9im01.png de9im02.png st_alphashape01.png
 /<<PKGBUILDDIR>>/debian/tmp/usr/share/doc/images/
 /usr/bin/install: cannot stat 'st_buildarea01.png': No such file or
 directory
 /usr/bin/install: cannot stat 'st_letters01.png': No such file or
 directory
 make[3]: *** [Makefile:242: images-install] Error 1
 Full buildlog:
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=s390x&ver=3.4.0%7Ebeta1%2Bdfsg-1%7Eexp2&stamp=1689441030&raw=0
 s390x]
 With the changes from PR132 there are still references to xmllint:
 $ grep xmllint * -r | grep -v ^debian/
 configure:# Extract the first word of "xmllint", so it can be a program
 name with args.
 configure:set dummy xmllint; ac_word=$2
 configure:      { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: xmllint
 is not installed so documentation cannot be checked" >&5
 configure:$as_echo "$as_me: WARNING: xmllint is not installed so
 documentation cannot be checked" >&2;}
 configure.ac:AC_PATH_PROG([XMLLINT], [xmllint], [])
 configure.ac:   AC_MSG_WARN([xmllint is not installed so documentation
 cannot be checked])
 doc/Makefile.in:check-xml: requirements_not_met_xmllint
 doc/Makefile.in:check-cheatsheets: requirements_not_met_xmllint
 doc/Makefile.in:requirements_not_met_xmllint:
 doc/Makefile.in:        @echo "configure was unable to find 'xmllint'
 which is required"
 doc/Makefile.in:        @echo "Install xmllint and then re-run configure.
 Alternatively "
 doc/README: * xmllint - http://xmlsoft.org
 utils/check_localized_cheatsheets.sh:for tag in $(xmllint --html --xpath
 '/html/body/span/sup/text()' "${SOURCE_FILE}"); do
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5446#comment:13>
