[postgis-tickets] [PostGIS] #5446: 3.4.0-beta1 fails to build (unable to parse postgis-out.xml)
PostGIS trac at osgeo.org
Sat Jul 15 12:01:57 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Bas Couwenberg):
 The changes from PR132 are included in the
 [https://buildd.debian.org/status/package.php?p=postgis&suite=experimental
 latest upload]:
  https://salsa.debian.org/debian-gis-
 team/postgis/-/commits/debian/3.4.0_beta1+dfsg-1_exp3?ref_type=tags
 This still fails:
 convert convert: Option length exceeds limit (path 'M 150,90
 149.0392640202,80.2454838992 146.1939766256,70.8658283817
 141.5734806151,62.221488349 135.3553390593,54.6446609407
 127.778511651,48.4265193849 119.1341716183,43.8060233744
 109.7545161008,40.9607359798 100,40 90.2454838992,40.9607359798
 80.8658283817,43.8060233744 72.221488349,48.4265193849
 64.6446609407,54.6446609407 58.4265193849,62.221488349
 53.8060233744,70.8658283817 50.9607359798,80.2454838992 50,90
 50.9607359798,99.7545161008 53.8060233744,109.1341716183
 58.4265193849,117.778511651 64.6446609407,125.3553390593
 72.221488349,131.5734806151 80.8658283817,136.1939766256
 90.2454838992,139.0392640202 100,140 109.7545161008,139.0392640202
 119.1341716183,136.1939766256 127.778511651,131.5734806151
 135.3553390593,125.3553390593 141.5734806151,117.778511651
 146.1939766256,109.1341716183 149.0392640202,99.7545161008 150,90 M 125,90
 124.5196320101,94.8772580504 123.0969883128,99.5670858091
 120.7867403076,103.8892558255 117.6776695297,107.6776695297
 113.8892558255,110.7867403076 109.5670858091,113.096).
 Failure return code (198) from command: convert -size 200x200 xc:none
 -fill "#C0D0F080" -stroke "#6495ED" -strokewidth 2 -draw "path 'M 150,90
 113.8892558255,110.7867403076 109.5670858091,113.0969883128
 104.8772580504,114.5196320101 100,115 95.1227419496,114.5196320101
 90.4329141909,113.0969883128 86.1107441745,110.7867403076
 82.3223304703,107.6776695297 79.2132596924,103.8892558255
 76.9030116872,99.5670858091 75.4803679899,94.8772580504 75,90
 75.4803679899,85.1227419496 76.9030116872,80.4329141909
 79.2132596924,76.1107441745 82.3223304703,72.3223304703
 86.1107441745,69.2132596924 90.4329141909,66.9030116872
 95.1227419496,65.4803679899 100,65 104.8772580504,65.4803679899
 109.5670858091,66.9030116872 113.8892558255,69.2132596924
 117.6776695297,72.3223304703 120.7867403076,76.1107441745
 123.0969883128,80.4329141909 124.5196320101,85.1227419496 125,90 '" -flip
 tmp0.pngconvert convert: Request did not return an image.
 Failure return code (1) from command: convert tmp[0-9].png -background
 white -flatten st_buildarea01.pngconvert convert: Unable to open file
 (st_buildarea01.png) [No such file or directory].
 Failure return code (1) from command: convert st_buildarea01.png -depth 8
 st_buildarea01.pngreading styles from wkt/styles.conf
 convert convert: Option length exceeds limit (path 'M 143.4,141.6
 145.6,141.6 147.8,141.4 150,141.2 152,141 154.3,140.6 156.3,140.2
 158.1,139.7 160.1,139.1 161.9,138.5 163.7,137.7 165.5,136.9 167.1,136.1
 168.7,135.1 170.3,134.1 171.7,132.9 173.1,131.7 174.6,130.5 175.8,129.1
 177,127.7 178,126.1 179,124.5 180,122.9 181,121.3 181.8,119.5 182.6,117.6
 183.2,115.6 183.8,113.6 184.2,111.6 184.6,109.6 184.8,107.4 185,105.2
 185,102.8 185,63 185,60.6 184.8,58.4 184.6,56.1 184.2,54.1 183.8,52.1
 183.4,50.1 182.8,48.1 182,46.3 181.2,44.5 180.4,42.9 179.4,41.3 178.4,39.7
 177.2,38.3 176,36.9 174.8,35.4 173.3,34.2 171.9,33 170.3,32 168.9,30.8
 167.3,30 165.5,29 163.9,28.2 162.1,27.4 160.3,26.6 158.5,26 156.5,25.4
 154.5,25 152.4,24.6 150.2,24.2 148,24 145.8,24 143.6,24 141.4,24
 139.2,24.2 137,24.4 134.8,24.6 132.8,25 130.7,25.4 128.7,26 126.7,26.6
 124.9,27.2 123.1,28 121.3,28.8 119.7,29.8 118.1,30.8 116.5,31.8 115.1,32.8
 113.7,34 112.3,35.2 111,36.7 109.8,38.1 108.8,39.5 107.8,41.1 106.8,42.7
 105.8,44.5 105,46.3 104.2,48.1 103.6,50.1 103,52.1 102.6,54.1 102.2,56.3
 102,58).
 -fill "#ff000020" -stroke "#770000" -strokewidth 2 -draw "path 'M
 74.3,173.3 113.5,173.3 111.7,171.5 75.5,82.7 75.5,26.8 77.3,25 41.2,25
 43.2,26.8 43.2,82.7 6.8,171.5 5,173.3 44.2,173.3 42.4,171.5 51.2,148.8
 59.3,120.3 67.5,149.4 76.1,171.5 74.3,173.3 '" -fill "#ff000020" -stroke
 "#770000" -strokewidth 2 -draw "path 'M 143.4,141.6 145.6,141.6
 147.8,141.4 150,141.2 152,141 154.3,140.6 156.3,140.2 158.1,139.7
 160.1,139.1 161.9,138.5 163.7,137.7 165.5,136.9 167.1,136.1 168.7,135.1
 170.3,134.1 171.7,132.9 173.1,131.7 174.6,130.5 175.8,129.1 177,127.7
 102,58.6 101.8,60.8 101.8,63 101.8,102.8 101.8,105.2 102,107.4 102.2,109.6
 102.6,111.6 103,113.6 103.4,115.6 104,117.6 104.8,119.5 105.6,121.3
 106.4,122.9 107.4,124.5 108.4,126.1 109.6,127.5 110.8,128.9 112.1,130.3
 113.5,131.5 114.9,132.7 116.5,133.7 117.9,134.7 119.7,135.7 121.3,136.7
 123.1,137.5 124.9,138.3 126.7,138.9 128.7,139.5 130.5,140.2 132.5,140.6
 134.8,141 136.8,141.2 139,141.4 141.2,141.6 143.4,141.6 M 153.2,103.2
 150.2,108.6 143.6,110.6 136.8,108.8 133.8,103.2 133.8,63 136.6,57.6
 143.2,55.5 149.8,57.4 153.2,63 153.2,103.2 '" -flip tmp0.pngconvert
 white -flatten st_letters01.pngconvert convert: Unable to open file
 (st_letters01.png) [No such file or directory].
 Failure return code (1) from command: convert st_letters01.png -depth 8
 st_letters01.pngreading styles from wkt/styles.conf
 mkdir -p /<<PKGBUILDDIR>>/debian/tmp/usr/share/doc/images
 /usr/bin/install -c -m 644 de9im01.png de9im02.png st_alphashape01.png
 /<<PKGBUILDDIR>>/debian/tmp/usr/share/doc/images/
 /usr/bin/install: cannot stat 'st_buildarea01.png': No such file or
 directory
 /usr/bin/install: cannot stat 'st_letters01.png': No such file or
 directory
 make[3]: *** [Makefile:242: images-install] Error 1
 Full buildlogs:
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=all&ver=3.4.0%7Ebeta1%2Bdfsg-1%7Eexp3&stamp=1689447088&raw=0
 all],
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=s390x&ver=3.4.0%7Ebeta1%2Bdfsg-1%7Eexp3&stamp=1689447205&raw=0
 s390x]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5446#comment:14>
