[postgis-tickets] [PostGIS] #5446: 3.4.0-beta1 fails to build (unable to parse postgis-out.xml)
trac at osgeo.org
Sat Jul 15 12:26:25 PDT 2023
Reporter: Bas Couwenberg | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.0
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Comment (by strk):
I think the convert command is being called by the generate.c script which
is failing to exit with a failure when convert fails, I'm going to fix
that as the first thing.
What version of imagemagick do you have there ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5446#comment:15>
