[postgis-tickets] [PostGIS] #5446: 3.4.0-beta1 fails to build (unable to parse postgis-out.xml)
PostGIS trac at osgeo.org
Sat Jul 15 21:28:05 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Bas Couwenberg):
 Replying to [comment:17 strk]:
 > Answering myself: graphicsmagick-imagemagick-compat all
 1.4+really1.3.40-4 [13.8 kB]
 That's interesting, because on my system the build uses imagemagick
 (8:6.9.11.60+dfsg-1.6), there the build succeeds.
 On the buildds graphicsmagick-imagemagick-compat (1.4+really1.3.40-4) is
 used where it fails. graphicsmagick-imagemagick-compat
 Provides/Replaces/Conflicts imagemagick.
 Adding a version constraint to the build dependency might suffice to not
 use graphicsmagick on the buildds.
 Replying to [comment:18 strk]:
 > do you mind if we close this (unable to parse) if that part is fixed and
 move to another ticket for the imagemagick issue ?
 That's fine. All the Trac notifications get flagged as spam, which hinders
 my response time.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5446#comment:19>
