[postgis-tickets] [PostGIS] #5446: 3.4.0-beta1 fails to build (unable to parse postgis-out.xml)
PostGIS trac at osgeo.org
Mon Jul 17 07:04:18 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"b2df8046681ac9e644e278b63a59259f8763193b/git" b2df804/git]:
 {{{#!CommitTicketReference repository="git"
 revision="b2df8046681ac9e644e278b63a59259f8763193b"
 Reduce imagemagick command line length
 Use temporary files for writing draw commands.
 Reduces the odds of hitting a command line length limit
 References #5446
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5446#comment:20>
