[postgis-tickets] [PostGIS] #5446: 3.4.0-beta1 fails to build (unable to parse postgis-out.xml)
PostGIS trac at osgeo.org
Mon Jul 17 07:05:51 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 Bas: with [b2df8046681ac9e644e278b63a59259f8763193b/git] the commandline
 should be shorter, if you want go give graphicsmagick another try
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5446#comment:21>
