[postgis-tickets] [PostGIS] #5444: 3.4.0-beta1 fails to build (postgis--TEMPLATED--TO--ANY.sql is missing)
PostGIS trac at osgeo.org
Wed Jul 19 15:06:00 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 I don't think install targets should depend on other install targets, as
 those targets are phony so will run again if invoked again.
 From the logs it is clear that the install fo the TEMPLATED--TO--ANY file
 is done before the attempt to symlink it.
 Is `<<PKGBUILDDIR>>` the actual directory name or some string replacement
 before printing logs ?
 The "is missing" message is emitted by perl's -f operator here:
 And then not found by the `-f` perl operator here:
 https://git.osgeo.org/gitea/postgis/postgis/src/tag/3.4.0beta1/loader/postgis.pl#L89
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5444#comment:5>
