[postgis-tickets] [PostGIS] #5444: 3.4.0-beta1 fails to build (postgis--TEMPLATED--TO--ANY.sql is missing)
PostGIS trac at osgeo.org
Wed Jul 19 20:27:31 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Bas Couwenberg):
 > Is <<PKGBUILDDIR>> the actual directory name or some string replacement
 before printing logs ?
 It's a replacement.
 From the buildlog:
 I: NOTICE: Log filtering will replace 'build/postgis-
 o8Pezi/postgis-3.4.0~beta1+dfsg' with '<<PKGBUILDDIR>>'
 I: NOTICE: Log filtering will replace 'build/postgis-o8Pezi' with
 '<<BUILDDIR>>'
 So the absolute path is:
 `/build/postgis-
 o8Pezi/postgis-3.4.0~beta1+dfsg/debian/tmp/usr/share/postgresql/15`
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5444#comment:6>
