[postgis-tickets] [PostGIS] #5444: 3.4.0-beta1 fails to build (postgis--TEMPLATED--TO--ANY.sql is missing)
PostGIS trac at osgeo.org
Thu Jul 20 00:15:35 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 I don't understand why the target directory is found to be unexistent as
 it was craeted as the first thing:
 ---- Making install in postgis
 make[4]: Entering directory '/<<PKGBUILDDIR>>/extensions/postgis'
 /bin/mkdir -p
 '/<<PKGBUILDDIR>>/debian/tmp/usr/share/postgresql/15/extension'
 tpl='postgis--ANY--3.4.0beta1.sql'; \
 /usr/bin/install -c -m 644 sql/${tpl}
 "/<<PKGBUILDDIR>>/debian/tmp/usr/share/postgresql/15/extension/${tpl}"; \
 /usr/bin/install -c -m 644 "sql/postgis--TEMPLATED--TO--ANY.sql"
 "/<<PKGBUILDDIR>>/debian/tmp/usr/share/postgresql/15/extension/postgis--
 TEMPLATED--TO--ANY.sql"; \
 ln -fs "postgis--TEMPLATED--TO--ANY.sql"
 3.4.0beta1--ANY.sql;
 /usr/bin/install: cannot create regular file
 '/<<PKGBUILDDIR>>/debian/tmp/usr/share/postgresql/15/extension/postgis--
 ANY--3.4.0beta1.sql': No such file or directory
 TEMPLATED--TO--ANY.sql': No such file or directory
 /bin/mkdir -p
 /usr/bin/install -c -m 644 .//postgis.control
 '/<<PKGBUILDDIR>>/debian/tmp/usr/share/postgresql/15/extension/'
 /usr/bin/install -c -m 644  postgis.control sql/postgis--3.4.0beta1.sql
 sql/postgis--unpackaged.sql sql/postgis--unpackaged--3.4.0beta1.sql
 sql/postgis--ANY--3.4.0beta1.sql
 make[4]: Leaving directory '/<<PKGBUILDDIR>>/extensions/postgis'
 It's also created twice for some reason
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5444#comment:8>
