[postgis-tickets] [PostGIS] #5444: 3.4.0-beta1 fails to build (postgis--TEMPLATED--TO--ANY.sql is missing)
PostGIS trac at osgeo.org
Thu Jul 20 00:18:24 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 In any case I think this dependency is encoded wrong:
 install: install-upgrade-paths
 As it's really the other way around, but as we're using PGXS that
 construct was the easiest to attach something to the "install" pre-defined
 target. We'd need a way to run something *after* the predefined install
 target, I guess.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5444#comment:9>
