[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-48-ge16e1e9ac
Thu Jul 20 20:59:56 PDT 2023
the project "PostGIS".
       via  e16e1e9ac9140aae46446d949976ef97129c6a9b (commit)
      from  ec00ef3d9d49a89bf727b732acfa0ebb9809d1d3 (commit)
revisions in full, below.
commit e16e1e9ac9140aae46446d949976ef97129c6a9b
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Jul 20 23:59:10 2023 -0400
    WINNIE FIXES
     - Fix typo in include file, should be winnie_common.sh (not .h)
     - Move more shared variables to winnie_common.sh
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index 3ec9e8411..f0d2a7b76 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -1,80 +1,6 @@
 #!/usr/bin/env bash
-. $(dirname $0)/winnie_common.h
-set -e
-if  [[ "${OVERRIDE}" == '' ]] ; then
-	export GEOS_VER=3.10.2
-	export GDAL_VER=3.4.2
-	export PROJ_VER=7.2.1
-	export SFCGAL_VER=1.4.1
-	export CGAL_VER=5.3
-	export ICON_VER=1.16
-	export ZLIB_VER=1.2.11
-  export PROTOBUF_VER=3.2.0
-	export PROTOBUFC_VER=1.2.1
-	export JSON_VER=0.12
-	export PROJSO=libproj-19.dll
-fi;
-export PROTOBUF_VER=3.2.0
-export PROTOBUFC_VER=1.2.1
-export JSON_VER=0.12
-export PCRE_VER=8.33
-if  [[ "${ICON_VER}" == '' ]] ; then
-  export ICON_VER=1.15
-fi;
-echo "ICON_VER ${ICON_VER}"
-#set to something even if override is on but not set
-if  [[ "${ZLIB_VER}" == '' ]] ; then
-fi;
-if  [[ "${LIBXML_VER}" == '' ]] ; then
-  export LIBXML_VER=2.7.8
-fi;
-if  [[ "${CGAL_VER}" == '' ]] ; then
-fi;
-#export GDAL_VER=2.4.0
-#export PROJ_VER=5.2.0
-echo "ZLIB_VER $ZLIB_VER"
-echo "PROJ_VER $PROJ_VER"
-echo "LIBXML_VER $LIBXML_VER"
-echo "CGAL_VER $CGAL_VER"
-export PROJECTS=/projects
-export MINGPROJECTS=/projects
-export PATHOLD=$PATH
-if [ "$OS_BUILD" == "64" ] ; then
-	export MINGHOST=x86_64-w64-mingw32
-else
-	export MINGHOST=i686-w64-mingw32
-fi;
-echo PATH AFTER: $PATH
-#export PG_VER=9.2beta2
-export PGWINVER=${PG_VER}edb
-export WORKSPACE=`pwd`
-echo PATH BEFORE: $PATH
-#export PGHOST=localhost
-#export PGPORT=8442
-export PGUSER=postgres
-#export GEOS_VER=3.4.0dev
-#export GDAL_VER=1.9.1
-export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
-export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}edb
+. $(dirname $0)/winnie_common.sh
 if [ -n "$SOURCE_FOLDER" ]; then
   export POSTGIS_SRC=${PROJECTS}/postgis/$SOURCE_FOLDER
@@ -93,18 +19,8 @@ export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POS
 #export POSTGIS_SRC=${PROJECTS}/postgis/trunk
-export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}
-export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig::${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
-export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
-CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
-#add protobuf
-export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 5b6faf08a..7cd652347 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -4,94 +4,13 @@
 ## and are passed in by the jenkins job process
-#export OS_BUILD=64
-#export OS_BUILD=32
-#export GCC_TYPE=
-#if no override is set - use these values
-#otherwise use the ones jenkins passes thru
-#!/usr/bin/env bash
-	export GEOS_VER=3.10.3
-	export CURL_VER=7.73
-fi;
-fi;
-if  [[ "${CURL_VER}" == '' ]] ; then
-fi;
-echo "CURL_VER ${CURL_VER}"
-fi;
-  export LIBXML_VER=2.9.9
-fi;
-fi;
-export PGHOST=localhost
 WEB=/home/www/postgis/htdocs
 DWN=${WEB}/download
-export PATHOLD="/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin"
-export PGPATHEDB=${PGPATH}edb
-#export PROJSO=libproj-13.dll
 	cd $POSTGIS_SRC
@@ -117,7 +36,6 @@ export REL_PGVER=${PG_VER//./} #strip the period
 export RELDIR=${PROJECTS}/postgis/builds/${POSTGIS_MINOR_VER}
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}${GCC_TYPE}
 #PATH="${PGPATH}/bin:${PGPATH}/lib:${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gtkw${OS_BUILD}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
 #echo PATH AFTER: $PATH
 outdir="${RELDIR}/${RELVERDIR}"
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 49ba72205..d75891bf9 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -1,78 +1,17 @@
 #!/usr/bin/env bash
 echo "MSYS2_ARG_CONV_EXCL=$MSYS2_ARG_CONV_EXCL"
-	export GEOS_VER=3.11.0
-fi;
-fi;
-fi;
-fi;
-fi;
-else
-fi;
 #export PGPORT=8442
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index 7c9dde5a2..cf9223e59 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -5,6 +5,100 @@
 set -e
+export PROJECTS=/projects
 # Don't convert paths
 # See https://trac.osgeo.org/postgis/ticket/5436#comment:5
 export MSYS2_ARG_CONV_EXCL=/config/tags
+if  [[ "${OVERRIDE}" == '' ]] ; then
+	export GEOS_VER=3.10.2
+	export GDAL_VER=3.4.2
+	export PROJ_VER=7.2.1
+	export SFCGAL_VER=1.4.1
+	export CGAL_VER=5.3
+	export ICON_VER=1.16
+	export ZLIB_VER=1.2.11
+  export PROTOBUF_VER=3.2.0
+	export PROTOBUFC_VER=1.2.1
+	export JSON_VER=0.12
+	export PROJSO=libproj-19.dll
+fi;
+export PROTOBUF_VER=3.2.0
+export PROTOBUFC_VER=1.2.1
+export JSON_VER=0.16
+export PCRE_VER=8.33
+#export OS_BUILD=64
+#export PGPORT=8442
+#export OS_BUILD=32
+#export GCC_TYPE=
+#if no override is set - use these values
+#otherwise use the ones jenkins passes thru
+if  [[ "${ICON_VER}" == '' ]] ; then
+  export ICON_VER=1.17
+fi;
+echo "ICON_VER ${ICON_VER}"
+#set to something even if override is on but not set
+if  [[ "${ZLIB_VER}" == '' ]] ; then
+  export ZLIB_VER=1.2.13
+fi;
+if  [[ "${LIBXML_VER}" == '' ]] ; then
+  export LIBXML_VER=2.9.14
+fi;
+if  [[ "${CGAL_VER}" == '' ]] ; then
+fi;
+#export GDAL_VER=2.4.0
+#export PROJ_VER=5.2.0
+echo "ZLIB_VER $ZLIB_VER"
+echo "PROJ_VER $PROJ_VER"
+echo "LIBXML_VER $LIBXML_VER"
+echo "CGAL_VER $CGAL_VER"
+export MINGPROJECTS=/projects
+export PATHOLD="/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin"
+if [ "$OS_BUILD" == "64" ] ; then
+	export MINGHOST=x86_64-w64-mingw32
+else
+	export MINGHOST=i686-w64-mingw32
+fi;
+#export PG_VER=9.2beta2
+export PGWINVER=${PG_VER}edb
+export WORKSPACE=`pwd`
+echo PATH BEFORE: $PATH
+#export PGHOST=localhost
+export PGUSER=postgres
+#export GEOS_VER=3.4.0dev
+#export GDAL_VER=1.9.1
+export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
+export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}edb
+export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
+export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig::${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
+export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
+CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
+#add protobuf
+export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+echo "PATH AFTER: $PATH"
Summary of changes:
 ci/winnie/build_postgis.sh   | 86 +---------------------------------------
 ci/winnie/package_postgis.sh | 84 +--------------------------------------
 ci/winnie/regress_postgis.sh | 65 +-----------------------------
 ci/winnie/winnie_common.sh   | 94 ++++++++++++++++++++++++++++++++++++++++++++
 4 files changed, 98 insertions(+), 231 deletions(-)
hooks/post-receive
