[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-49-g0bc0fb6aa
Thu Jul 20 23:00:19 PDT 2023
the project "PostGIS".
       via  0bc0fb6aa09ea6946627298cc42d0666fff52e10 (commit)
      from  e16e1e9ac9140aae46446d949976ef97129c6a9b (commit)
revisions in full, below.
commit 0bc0fb6aa09ea6946627298cc42d0666fff52e10
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jul 21 02:00:13 2023 -0400
    Cleanup of path on winnie. Version updates
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index d75891bf9..aae147757 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -42,21 +42,6 @@ export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}
-export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
-export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
-CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
-#needed for proj.db to be found during cunit - for some reason on winnie it doesn't set
-if [ -d "${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj" ]; then
-export PROJ_LIB=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
-else
-export PROJ_LIB=${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
-fi
-#add protobuf
-export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 echo PATH AFTER: $PATH
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index cf9223e59..eabc64de8 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -16,9 +16,9 @@ if  [[ "${OVERRIDE}" == '' ]] ; then
 	export PROJ_VER=7.2.1
 	export SFCGAL_VER=1.4.1
 	export CGAL_VER=5.3
-	export ICON_VER=1.16
+	export ICON_VER=1.17
 	export ZLIB_VER=1.2.11
-  export PROTOBUF_VER=3.2.0
+	export PROTOBUF_VER=3.2.0
 	export PROTOBUFC_VER=1.2.1
 	export JSON_VER=0.12
 	export PROJSO=libproj-19.dll
@@ -68,7 +68,7 @@ echo "LIBXML_VER $LIBXML_VER"
 echo "CGAL_VER $CGAL_VER"
 export PROJECTS=/projects
 export MINGPROJECTS=/projects
-export PATHOLD="/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin"
+export PATHOLD=$PATH
 if [ "$OS_BUILD" == "64" ] ; then
 	export MINGHOST=x86_64-w64-mingw32
@@ -76,6 +76,13 @@ else
 	export MINGHOST=i686-w64-mingw32
 fi;
+#needed for proj.db to be found during cunit - for some reason on winnie it doesn't set
+if [ -d "${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj" ]; then
+export PROJ_LIB=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
+else
+export PROJ_LIB=${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
+fi
 #export PG_VER=9.2beta2
 export PGWINVER=${PG_VER}edb
 export WORKSPACE=`pwd`
@@ -92,6 +99,17 @@ export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}ed
 export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
+export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
+export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
+CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
+#add protobuf
+export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig::${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
Summary of changes:
 ci/winnie/regress_postgis.sh | 15 ---------------
 ci/winnie/winnie_common.sh   | 24 +++++++++++++++++++++---
 2 files changed, 21 insertions(+), 18 deletions(-)
hooks/post-receive
