[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-57-gb07b65a47
Mon Jul 24 01:27:38 PDT 2023
the project "PostGIS".
       via  b07b65a47a57de44c05b2ca4353a06541d40f80f (commit)
      from  605ffdf8ecea86d8f31b1c5dc589cfd9a2a8c845 (commit)
revisions in full, below.
commit b07b65a47a57de44c05b2ca4353a06541d40f80f
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jul 21 22:03:57 2023 +0200
    Update GEOS version warning
diff --git a/configure.ac b/configure.ac
index 3d4a755e0..fc74a71e7 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1894,16 +1894,12 @@ AC_MSG_RESULT([  convert:              ${CONVERT}])
 AC_MSG_RESULT([  mathml2.dtd:          ${MATHML2_DTD}])
 AC_MSG_RESULT()
-if test "$POSTGIS_GEOS_VERSION" -lt 30900; then
+if test "$POSTGIS_GEOS_VERSION" -lt 31200; then
 AC_MSG_WARN([ --------- GEOS VERSION WARNING ------------ ])
 AC_MSG_WARN([  You are building against GEOS ${GEOS_FULL_VERSION}.])
 AC_MSG_WARN([])
 AC_MSG_WARN([  To take advantage of _all_ the features of ])
-AC_MSG_WARN([  PostGIS, GEOS 3.9.0 or higher is required.])
-AC_MSG_WARN([])
-AC_MSG_WARN([  For _many_ features, GEOS 3.6.0 is enough.])
-AC_MSG_WARN([])
-AC_MSG_WARN([  We recommend GEOS 3.8.0 or higher])
+AC_MSG_WARN([  PostGIS, GEOS 3.12.0 or higher is required.])
 AC_MSG_WARN([])
 AC_MSG_WARN([  You can download the latest versions from ])
 AC_MSG_WARN([  http://geos.osgeo.org/ ])
Summary of changes:
 configure.ac | 8 ++------
 1 file changed, 2 insertions(+), 6 deletions(-)
hooks/post-receive
