[postgis-tickets] [SCM] PostGIS branch stable-3.3 updated. 3.3.3-29-gab2b06547
Mon Jul 24 08:55:25 PDT 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  ab2b065477917c568c61d74b1a227bfa2dd4b511 (commit)
      from  95d92985ba167ac9e357ab9405d7b6e7914da731 (commit)
revisions in full, below.
commit ab2b065477917c568c61d74b1a227bfa2dd4b511
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jul 24 11:54:23 2023 -0400
    Updated README.postgis instructions
    for apt based systems (Jelte Fennema)
    References #5452 for PostGIS 3.3.4
diff --git a/NEWS b/NEWS
index 658c45845..80b022526 100644
--- a/NEWS
+++ b/NEWS
@@ -16,6 +16,8 @@ YYYY/MM/DD
   - #5385, Postgres malloc assertion fail when
            using pg_cancel_backend with ST_AsMVT
            (Regina Obe, Paul Ramsey)
+  - #5452, Updated README.postgis for apt-based systems
+           (Jelte Fennema)
 * Breaking Changes *
     - #5385, Take out interruptability of ST_AsMVT
diff --git a/README.postgis b/README.postgis
index 4130c070b..ed85cfc8e 100644
--- a/README.postgis
+++ b/README.postgis
@@ -41,6 +41,10 @@ PostGIS is compatible with PostgreSQL 11 and above.
 You *must* have the full PostgreSQL - including server headers - installed for
 this to work.
+For apt-based systems you can run this command to install the below dependencies (except for GTK):
+  sudo apt-get install libproj-dev libgeos-dev libxml2-dev gettext libjson-c-dev libgdal-dev libsfcgal-dev libprotobuf-c-dev protobuf-c-compiler
 * PROJ4 (Required, Version 5.2.0 or higher):
   The PROJ4 catographic projection library is required if you want to use the
@@ -81,10 +85,6 @@ this to work.
     http://github.com/json-c/json-c/wiki
-  You can get it installed in apt-based systems using:
-    apt-get install libjson0-dev
 * GDAL (Optional, Version 2 or higher 3+ is strongly recommended)
   GDAL (https://gdal.org) is *required* if you want to compile PostGIS
@@ -105,10 +105,6 @@ this to work.
     https://github.com/protobuf-c/protobuf-c
-  To get packages on apt-based systems:
-    apt-get install libprotobuf-c-dev protobuf-c-compiler
 * GTK (Optional,  Version 2 series: 2.2.0 or higher)
   The GTK library is required to build the GUI version of shp2pgsql
Summary of changes:
 NEWS           |  2 ++
 README.postgis | 12 ++++--------
 2 files changed, 6 insertions(+), 8 deletions(-)
hooks/post-receive
