[postgis-tickets] [PostGIS] #5448: Test failures on i386
PostGIS trac at osgeo.org
Wed Jul 26 22:57:44 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by robe):
 I'm able to replicate the error, using chroot
 Sorry for detail, just for future reference since I never remember these
 apt install git-buildpackage
 DIST=sid ARCH=i386 git-pbuilder create
 sudo cowbuilder --login --basepath /var/cache/pbuilder/base-sid-i386.cow
 ## Add apt sources
 echo "deb http://deb.debian.org/debian/ experimental main contrib non-
 free" >> /etc/apt/sources.list
 echo "deb-src http://deb.debian.org/debian/ experimental main contrib non-
 sed -i 's/^#deb-src/deb-src/' /etc/apt/sources.list
 apt update
 ## Install tools you need (vim, less, gdb, etc)
 ## Get postgis source package
 cd /tmp/buildd
 apt source -t experimental postgis
 cd postgis-*/
 ## Install build dependencies
 apt build-dep postgis
 ## Delete patch which skips the failing test
 apt install quilt
 ## Build the package
 DEB_BUILD_OPTIONS="parallel=3" dpkg-buildpackage -uc -uc 2>&1 | tee
 ../postgis.build
 Are you building with lto by chance. I didn't check that closely but saw a
 bunch of flto notices.
 I recall we had issues before with lto when we were shipping 3.3.0 and you
 disabled that switch as a work-around.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5448#comment:6>
