[postgis-tickets] [PostGIS] #5448: Test failures on i386
PostGIS trac at osgeo.org
Wed Jul 26 23:15:08 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Bas Couwenberg):
 Replying to [comment:6 robe]:
 > Are you building with lto by chance.
 Yes, that's default since dpkg 1.21.0, see:
 https://wiki.debian.org/ToolChain/LTO
 export DEB_BUILD_MAINT_OPTIONS=optimize=-lto
 Might be required on i386 then.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5448#comment:7>
