[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-81-gfab44d035
Fri Jul 28 12:27:35 PDT 2023
the project "PostGIS".
       via  fab44d035a2445ffbd916536ba2ee884cd336ffd (commit)
      from  09a0c95620008fa32f8ca8cca246ed3071161ce2 (commit)
revisions in full, below.
commit fab44d035a2445ffbd916536ba2ee884cd336ffd
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Jul 28 12:27:26 2023 -0700
    Reflect updates from MobilityDB on use of spheroid and line-locate-point, closes #5460
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index a27529e6c..69ed8f354 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1793,6 +1793,7 @@ extern int lwgeom_covers_lwgeom_sphere(const LWGEOM *lwgeom1, const LWGEOM *lwge
 extern LWGEOM * geography_substring(const LWLINE *line,
+    const SPHEROID *s,
     double from, double to,
     double tolerance);
diff --git a/liblwgeom/lwgeodetic_measures.c b/liblwgeom/lwgeodetic_measures.c
index e1fad3a7f..1bca0a795 100644
--- a/liblwgeom/lwgeodetic_measures.c
+++ b/liblwgeom/lwgeodetic_measures.c
@@ -55,72 +55,55 @@
  * Find interpolation point p between geography points p1 and p2
  * so that the len(p1,p) == len(p1,p2)
  * f and p falls on p1,p2 segment
- * @param[in] p1,p2 3D-space points we are interpolating between
- * @param[in] v1,v2 real values and z/m coordinates
- * @param[in] f Fraction
- * @param[out] p Result
 static void
-interpolate_point4d_sphere(
-	const POINT3D *p1, const POINT3D *p2,
-	const POINT4D *v1, const POINT4D *v2,
-	double f, POINT4D *p)
-	/* Calculate interpolated point */
-	POINT3D mid;
-	mid.x = p1->x + ((p2->x - p1->x) * f);
-	mid.y = p1->y + ((p2->y - p1->y) * f);
-	mid.z = p1->z + ((p2->z - p1->z) * f);
-	normalize(&mid);
-	/* Calculate z/m values */
-	GEOGRAPHIC_POINT g;
-	cart2geog(&mid, &g);
-	p->x = rad2deg(g.lon);
-	p->y = rad2deg(g.lat);
-	p->z = v1->z + ((v2->z - v1->z) * f);
-	p->m = v1->m + ((v2->m - v1->m) * f);
+interpolate_point4d_spheroid(
+	const POINT4D *p1, const POINT4D *p2, POINT4D *p,
+	const SPHEROID *s, double f)
- * @brief Returns the length of the point array wrt the sphere
-static double
-ptarray_length_sphere(const POINTARRAY *pa)
-	GEOGRAPHIC_POINT a, b;
-	POINT4D p;
-	uint32_t i;
-	double length = 0.0;
+	GEOGRAPHIC_POINT g, g1, g2;
+	geographic_point_init(p1->x, p1->y, &g1);
+	geographic_point_init(p2->x, p2->y, &g2);
+	int success;
+	double dist, dir;
-	/* Return zero on non-sensical inputs */
-	if ( ! pa || pa->npoints < 2 )
-		return 0.0;
-	/* Initialize first point */
-	getPoint4d_p(pa, 0, &p);
-	geographic_point_init(p.x, p.y, &a);
+	/* Special sphere case */
+	if ( s == NULL || s->a == s->b )
+		/* Calculate distance and direction between g1 and g2 */
+		dist = sphere_distance(&g1, &g2);
+		dir = sphere_direction(&g1, &g2, dist);
+		/* Compute interpolation point */
+		success = sphere_project(&g1, dist*f, dir, &g);
+	/* Spheroid case */
+	else
+		dist = spheroid_distance(&g1, &g2, s);
+		dir = spheroid_direction(&g1, &g2, s);
+		success = spheroid_project(&g1, s, dist*f, dir, &g);
-	/* Loop and sum the length for each segment */
-	for ( i = 1; i < pa->npoints; i++ )
+	/* If success, use newly computed lat and lon,
+	* otherwise return precomputed cartesian result */
+	if (success == LW_SUCCESS)
-		getPoint4d_p(pa, i, &p);
-		geographic_point_init(p.x, p.y, &b);
-		/* Add this segment length to the total */
-		length += sphere_distance(&a, &b);
+		p->x = rad2deg(longitude_radians_normalize(g.lon));
+		p->y = rad2deg(latitude_radians_normalize(g.lat));
-	return length;
  * @brief Return the part of a line between two fractional locations.
 LWGEOM *
 	const LWLINE *lwline,
 	double tolerance)
@@ -129,7 +112,6 @@ geography_substring(
 	LWGEOM *lwresult;
 	POINT4D pt;
 	POINT4D p1, p2;
-	POINT3D q1, q2;
 	GEOGRAPHIC_POINT g1, g2;
 	int nsegs, i;
 	double length, slength, tlength;
@@ -146,7 +128,7 @@ geography_substring(
 		ipa->npoints);
 	/* Compute total line length */
-	length = ptarray_length_sphere(ipa);
+	length = ptarray_length_spheroid(ipa, s);
 	/* Get 'from' and 'to' lengths */
 	from = length * from;
@@ -162,7 +144,12 @@ geography_substring(
 		geographic_point_init(p2.x, p2.y, &g2);
 		/* Find the length of this segment */
-		slength = sphere_distance(&g1, &g2);
+		if ( s->a == s->b )
+			slength = s->radius * sphere_distance(&g1, &g2);
+		else
+			slength = spheroid_distance(&g1, &g2, s);
 		/*  We are before requested start. */
 		if (state == 0) /* before */
@@ -196,9 +183,7 @@ geography_substring(
 				/* Our start is between first and second point */
 				dseg = (from - tlength) / slength;
-				geog2cart(&g1, &q1);
-				geog2cart(&g2, &q2);
-				interpolate_point4d_sphere(&q1, &q2, &p1, &p2, dseg, &pt);
+				interpolate_point4d_spheroid(&p1, &p2, &pt, s, dseg);
 				ptarray_append_point(dpa, &pt, LW_FALSE);
 				/* We're inside now, but will check 'to' point as well */
 				state = 1;
@@ -238,9 +223,7 @@ geography_substring(
 			else if (to < tlength + slength )
 				dseg = (to - tlength) / slength;
 				break;
@@ -322,9 +305,16 @@ geography_interpolate_points(
 	geographic_point_init(p1.x, p1.y, &g1);
 	for ( i = 0; i < ipa->npoints - 1 && points_found < points_to_interpolate; i++ )
+		double segment_length_frac;
 		getPoint4d_p(ipa, i+1, &p2);
-		double segment_length_frac = spheroid_distance(&g1, &g2, s) / length;
+			segment_length_frac = s->radius * sphere_distance(&g1, &g2) / length;
+		else
+			segment_length_frac = spheroid_distance(&g1, &g2, s) / length;
 		/* If our target distance is before the total length we've seen
 		* so far. create a new point some distance down the current
@@ -335,7 +325,7 @@ geography_interpolate_points(
 			double segment_fraction = (length_fraction - length_fraction_consumed) / segment_length_frac;
-			interpolate_point4d_sphere(&q1, &q2, &p1, &p2, segment_fraction, &pt);
+			interpolate_point4d_spheroid(&p1, &p2, &pt, s, segment_fraction);
 			ptarray_set_point4d(opa, points_found++, &pt);
 			length_fraction += length_fraction_increment;
diff --git a/postgis/geography_measurement.c b/postgis/geography_measurement.c
index e52671f4f..dc8bde060 100644
--- a/postgis/geography_measurement.c
+++ b/postgis/geography_measurement.c
@@ -1218,7 +1218,12 @@ Datum geography_line_substring(PG_FUNCTION_ARGS)
 	double to_fraction = PG_GETARG_FLOAT8(2);
 	LWLINE *lwline;
 	LWGEOM *lwresult;
+	SPHEROID s;
 	GSERIALIZED *result;
+	bool use_spheroid = true;
+	if ( PG_NARGS() > 3 && ! PG_ARGISNULL(3) )
+    	use_spheroid = PG_GETARG_BOOL(3);
 	/* Return NULL on empty argument. */
 	if ( gserialized_is_empty(gs) )
@@ -1253,7 +1258,13 @@ Datum geography_line_substring(PG_FUNCTION_ARGS)
 		PG_RETURN_NULL();
-	lwresult = geography_substring(lwline,
+	/* Initialize spheroid */
+	spheroid_init_from_srid(gserialized_get_srid(gs), &s);
+ 	/* Set to sphere if requested */
+	if ( ! use_spheroid )
+		s.a = s.b = s.radius;
+	lwresult = geography_substring(lwline, &s,
 		from_fraction, to_fraction, FP_TOLERANCE);
 	lwline_free(lwline);
@@ -1311,8 +1322,7 @@ Datum geography_line_interpolate_point(PG_FUNCTION_ARGS)
-	// spheroid_init_from_srid(fcinfo, srid, &s);
-	spheroid_init(&s, WGS84_MAJOR_AXIS, WGS84_MINOR_AXIS);
@@ -1376,8 +1386,7 @@ Datum geography_line_locate_point(PG_FUNCTION_ARGS)
 	else {
+		spheroid_init_from_srid(gserialized_get_srid(gs1), &s);
 	lwline = lwgeom_as_lwline(lwgeom_from_gserialized(gs1));
@@ -1457,8 +1466,7 @@ Datum geography_shortestline(PG_FUNCTION_ARGS)
+	spheroid_init_from_srid(gserialized_get_srid(g1), &s);
diff --git a/regress/core/geography.sql b/regress/core/geography.sql
index 1ad7e4e04..1c07be981 100644
--- a/regress/core/geography.sql
+++ b/regress/core/geography.sql
@@ -139,16 +139,17 @@ SELECT 'lrs_lip_1', ST_AsText(ST_LineInterpolatePoint(geography 'Linestring(4.35
 SELECT 'lrs_lip_2', ST_AsText(ST_LineInterpolatePoints(geography 'Linestring(4.35 50.85, 37.617222 55.755833)', 0.0, true), 2);
 SELECT 'lrs_lip_3', ST_AsText(ST_LineInterpolatePoints(geography 'Linestring(4.35 50.85, 37.617222 55.755833)', 1.0, false), 2);
 SELECT 'lrs_lip_4', ST_AsText(ST_LineInterpolatePoints(geography 'Linestring(4.35 50.85, 37.617222 55.755833)', 0.1, true), 2);
+SELECT 'lrs_lip_5', ST_AsText(ST_LineInterpolatePoints(geography 'Linestring(4.35 50.85, 37.617222 55.755833)', 0.1, false), 2);
 SELECT 'lrs_llp_1', round(ST_LineLocatePoint(geography 'linestring(0 1, 50 1)', geography 'Point(25 0)')::numeric, 2);
 SELECT 'lrs_llp_2', round(ST_LineLocatePoint(geography 'linestring(0 1, 50 1)', geography 'Point(-5 0)')::numeric, 2);
 SELECT 'lrs_llp_3', round(ST_LineLocatePoint(geography 'linestring(0 1, 50 1)', geography 'Point(55 0)')::numeric, 2);
 SELECT 'lrs_llp_4', round(ST_LineLocatePoint(geography 'linestring(0 1, 50 1)', geography 'Linestring(25 0,26 1)')::numeric, 2);
-SELECT 'lrs_substr_1', ST_AsText(ST_LineSubstring(geography 'linestring(0 1, 100 1)', 0.1, 0.2),2);
+SELECT 'lrs_substr_1', ST_AsText(ST_LineSubstring(geography 'linestring(0 20, 100 20)', 0.1, 0.2),2);
---SELECT 'lrs_cp_1', ST_AsText(ST_ClosestPoint(geography 'linestring(0 1, 50 1)', 'Point(25 0)'), 3);
---SELECT 'lrs_cp_2', ST_AsText(ST_ClosestPoint(geography 'Point(25 0)', geography 'linestring(0 1, 50 1)'), 3);
+--SELECT 'lrs_cp_1', ST_AsText(ST_ClosestPoint(geography 'Linestring(0 20, 50 20)', 'Point(25 20)'), 3);
+--SELECT 'lrs_cp_2', ST_AsText(ST_ClosestPoint(geography 'Point(25 20)', geography 'Linestring(0 20, 50 20)'), 3);
-SELECT 'lrs_sl_1', ST_AsText(ST_ShortestLine(geography 'linestring(0 1, 50 1)', 'Point(25 0)', true), 2);
+SELECT 'lrs_sl_1', ST_AsText(ST_ShortestLine(geography 'linestring(0 40, 50 40)', 'Point(25 40)', true), 2);
diff --git a/regress/core/geography_expected b/regress/core/geography_expected
index 4fc2e88c5..ae740cd52 100644
--- a/regress/core/geography_expected
+++ b/regress/core/geography_expected
@@ -58,10 +58,11 @@ lrs_empty_6|
 lrs_lip_1|POINT(4.35 50.85)
 lrs_lip_2|POINT(4.35 50.85)
 lrs_lip_3|POINT(37.62 55.76)
-lrs_lip_4|MULTIPOINT((7.22 51.72),(10.23 52.53),(13.37 53.26),(16.63 53.91),(20 54.46),(23.45 54.93),(26.96 55.29),(30.51 55.55),(34.07 55.7),(37.62 55.76))
+lrs_lip_4|MULTIPOINT((7.27 51.73),(10.3 52.54),(13.43 53.27),(16.67 53.91),(20 54.47),(23.42 54.93),(26.9 55.29),(30.44 55.55),(34.02 55.7),(37.62 55.76))
+lrs_lip_5|MULTIPOINT((7.27 51.73),(10.29 52.54),(13.43 53.27),(16.67 53.91),(20 54.46),(23.42 54.92),(26.9 55.29),(30.44 55.55),(34.02 55.7),(37.62 55.76))
 lrs_llp_1|0.50
 lrs_llp_2|0.00
 lrs_llp_3|1.00
 ERROR:  geography_line_locate_point: 2st arg is not a point
-lrs_substr_1|LINESTRING(6.37 1.13,14.43 1.27)
-lrs_sl_1|LINESTRING(25 0,25 1.1)
+lrs_substr_1|LINESTRING(9.28 23.25,18.97 25.93)
+lrs_sl_1|LINESTRING(25 40,25 42.79)
Summary of changes:
 liblwgeom/liblwgeom.h.in        |   1 +
 liblwgeom/lwgeodetic_measures.c | 112 ++++++++++++++++++----------------------
 postgis/geography_measurement.c |  22 +++++---
 regress/core/geography.sql      |   9 ++--
 regress/core/geography_expected |   7 +--
 5 files changed, 76 insertions(+), 75 deletions(-)
hooks/post-receive
