[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0beta1-82-g8b9b9630d
Fri Jul 28 12:36:29 PDT 2023
the project "PostGIS".
       via  8b9b9630dfc03db3733a203fb33304f9429b0be7 (commit)
      from  fab44d035a2445ffbd916536ba2ee884cd336ffd (commit)
revisions in full, below.
commit 8b9b9630dfc03db3733a203fb33304f9429b0be7
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jul 28 21:35:42 2023 +0200
    Review release procedure, especially in case of Debbie's failure
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index db3ef753a..d1fa0333d 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -94,8 +94,8 @@ Release procedure
     and ensure all the previous released minor versions are listed in it
   - Commit all changes
   - If this is a minor or major release (no branch exists):
-	   $ rev=x.x
-	   $ git checkout master; git checkout -b "stable-$rev"; git push -u osgeo stable-$rev
+	   $ rel=x.x # replace x.x with minor version (e.g. 2.3)
+	   $ git checkout master; git checkout -b "stable-$rel"; git push -u osgeo stable-$rev
 	   Go to: https://debbie.postgis.net and copy last branch version and make new job
 	   a) Replace PostGIS_* string params with new version
@@ -108,24 +108,53 @@ Release procedure
   - Check that bots are still green on https://trac.osgeo.org/postgis
-  - Tag branch:  (replace x.x and x.x.x with minor and micro version e.g 2.3, 2.3.1)
-     $ rev=x.x.x
+  - Tag branch:
+     $ rev=x.x.x # replace x.x.x with micro version (e.g 2.3.1)
      $ git tag -a $rev -m "Tagged release $rev"
+  - Push the tag:
      $ git push osgeo --tags
-  - Take tar ball and md5 from http://postgis.net/stuff/
-     (You might need to wait a few minutes to see it)
-     If impatient check status of job - https://debbie.postgis.net/job/PostGIS_Make_Dist/
-     If it fails, sh make_dist.sh $rev)
-  - Documentation should also have been built and should be in https://postgis.net/stuff
-     (this sometimes takes sometime so wait 15 minutes)
-  - Test generated tarball (including extension upgrade)
-  - Copy tarball and md5 files to ssh://upload.osgeo.org/osgeo/download/postgis/source
-    $ scp postgis-${rev}.tar.gz postgis-${rev}.tar.gz.md5 upload.osgeo.org:/osgeo/download/postgis/source
+  - Check if debbie's PostGIS_Make_Dist job completes successfully:
+    https://debbie.postgis.net/job/PostGIS_Make_Dist/
+  - If debbie job succeeds:
+    - Download tar ball from http://postgis.net/stuff/
+      $ wget debbie.postgis.net:/var/www/postgis_stuff/postgis-${rev}.tar.gz .
+    - Test generated tarball (including extension upgrade)
+    - Verify documentation have been published to https://postgis.net/stuff
+      (this sometimes takes sometime so wait 15 minutes)
+    - Download pdf, epub and doc-html files from http://postgis.net/stuff/
+      $ wget postgis.net/stuff/doc-html-${rev}.tar.gz
+      $ wget postgis.net/stuff/postgis-${rev}.{pdf,epub}
+  - If debbie job fails:
+    - Create the tarball locally:
+      $ sh make_dist.sh $rev
+    - Upload md5 file to https://postgis.net/stuff:
+      $ md5sum postgis-${rev}.tar.gz > postgis-${rev}.tar.gz.md5
+      $ scp postgis-${rev}.tar.gz.md5 debbie.postgis.net:/var/www/postgis_stuff
+    - Create the pdf and epub files:
+      $ make -C doc/ pdf epub
+    - Create the doc-html-${rev}.tar.gz file
+      ( check how ci/debbie/postgis_make_dist.sh does it )
+  - Copy tarball to ssh://upload.osgeo.org/osgeo/download/postgis/source
+    $ scp postgis-${rev}.tar.gz upload.osgeo.org:/osgeo/download/postgis/source
   - Copy pdf, epub and doc-html files to ssh://upload.osgeo.org/osgeo/download/postgis/docs
-    $ scp doc-html-${rev}.tar.gz postgis-${rev}.epub postgis-${rev}.pdf upload.osgeo.org:/osgeo/download/postgis/docs/
-  - Ensure md5 file is ALSO in https://postgis.net/stuff, if needed:
-    $ scp postgis-${rev}.tar.gz.md5 debbie.postgis.net:/var/www/postgis_stuff
+    $ scp doc-html-${rev}.tar.gz \
+          postgis-${rev}.epub \
+          postgis-${rev}.pdf \
+      upload.osgeo.org:/osgeo/download/postgis/docs/
   - PostGIS doc release versioned doc - http://postgis.net/documentation/
     - On postgis.net server, change /etc/nginx/sites-enabled/postgis.net (Versionless URL line )
Summary of changes:
 HOWTO_RELEASE | 61 +++++++++++++++++++++++++++++++++++++++++++----------------
 1 file changed, 45 insertions(+), 16 deletions(-)
hooks/post-receive
