[postgis-tickets] [SCM] postgis.net branch website updated. clarity-final-27-g8c3c801
Thu Jun 1 22:00:08 PDT 2023
the project "postgis.net".
The branch, website has been updated
       via  8c3c801a5201605ca659ca0aab5522533661a2b3 (commit)
       via  b8bb8d2c21ba618bde0f51d77700e747bc4bc844 (commit)
      from  97e6169e867d47b5917d77814db1967621a1da20 (commit)
revisions in full, below.
commit 8c3c801a5201605ca659ca0aab5522533661a2b3
Merge: b8bb8d2 97e6169
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jun 2 01:00:00 2023 -0400
    Merge branch 'website' of git.osgeo.org:postgis/postgis.net into website
commit b8bb8d2c21ba618bde0f51d77700e747bc4bc844
Date:   Fri Jun 2 00:47:07 2023 -0400
    Release notes for PostGIS bundle 3.3.3
diff --git a/content/documentation/getting_started/install_windows/enabling_postgis.md b/content/documentation/getting_started/install_windows/enabling_postgis.md
index 76991bc..320298a 100644
--- a/content/documentation/getting_started/install_windows/enabling_postgis.md
+++ b/content/documentation/getting_started/install_windows/enabling_postgis.md
@@ -59,8 +59,8 @@ CREATE EXTENSION h3_postgis;
 #### MobilityDB
 MobilityDB is for managing trajectory data.  Refer to https://github.com/MobilityDB/MobilityDB for details.
-The mobilitydb extension, is not yet part of the PostGIS Bundle, but you will find the in develop version
-available in the `extras` [PostgreSQL versioned](https://winnie.postgis.net/download/windows/) folders.  It will also be available in PostGIS bundle soon.
+The mobilitydb extension, was introduced in PostGIS Bundle 3.3.3 (for PostgreSQL 12 and above).
+You will also find available in the `extras` [PostgreSQL versioned](https://winnie.postgis.net/download/windows/) folders.
 ```postgres
 -- confirm you don't have any existing pre-loaded libraries,
@@ -76,11 +76,17 @@ ALTER SYSTEM SET max_locks_per_transaction = 128;
 From Windows services, restart the PostgreSQL service.
-Now you are ready to enable mobilitydb in a database:
+Now you are ready to enable mobilitydb in a database.
 CREATE EXTENSION mobilitydb;
+If you failed to do the above steps or restart your service, you might get an error
+when you run the create extension command of the sort:
+<span style="color:red">**"C:/Program Files/PostgreSQL/15/lib/libMobilityDB-1.1.dll": The specified module could not be found**</span>.
 See the [Getting Started]({{< ref "/documentation/getting_started/" >}}) section for more guidance.
diff --git a/content/documentation/getting_started/install_windows/released_versions.md b/content/documentation/getting_started/install_windows/released_versions.md
index 68b2632..f12602a 100644
--- a/content/documentation/getting_started/install_windows/released_versions.md
+++ b/content/documentation/getting_started/install_windows/released_versions.md
@@ -1,28 +1,25 @@
 title: Latest Released Version
-date: 2022-02-01
+date: 2023-06-01
 weight: 10
 geekdocHidden: true
 geekdocHiddenTocTree: false
-PostGIS 3.3.2 came out Nov 13, 2022. Windows PostGIS Bundle 3.3.2 was originally released Nov 21st, 2022 and rereleased on Dec 2nd, 2022.
+PostGIS 3.3.3 came out May 30th, 2023. Windows PostGIS Bundle 3.3.3 was released June 2nd, 2023.
-The rerelease includes updated pgRouting updated to 3.4.2 and a [fix for packaging issue of raster2pgsql](https://trac.osgeo.org/postgis/ticket/5292).
-There was also an issue with the PostgreSQL 13 which made it inaccessible from application stackbuilder.
+The rerelease includes an additional extension called [MobilityDb](https://mobilitydb.com/) (the develop 1.1 version for PostgreSQL 12-15).
+PostgreSQL 11 version does not include mobilitydb because it is not supported in MobilityDb 1.1.
 Binaries for versions of PostgreSQL 11-15 (64-bit) available in `Unreleased PostGIS Versions` and [OSGeo downloads][5]). Installers for 11-15(64-bit) and older releases of PostGIS are available on stackbuilder and [OSGeo downloads][5].
-New feature in this release is [h3-pg](https://github.com/zachasme/h3-pg) which includes `h3` and `h3_postgis` extensions for utilizing Uber's Hexagon indexing system within PostgreSQL.
 If you are using PostgreSQL < 11, use the PostGIS 3.2.3 bundle, because PostGIS 3.3+  does not support those versions.
-PostGIS 3.3.2 bundle includes:
+PostGIS 3.3.3 bundle includes:
-  * PostGIS 3.3.2 with MVT support, with raster, [GEOS](https://libgeos.org/posts/2022-11-14-geos-3-11-1-released/) 3.11.1, [PROJ](https://proj.org/download.html#past-releases) 7.2.1, [SFCGAL](http://sfcgal.org) support (1.4.1), address_standardizer, topology
+  * PostGIS 3.3.3 with MVT support, with raster, [GEOS](https://libgeos.org/posts/2023-03-16-geos-3-11-2-released/) 3.11.2, [PROJ](https://proj.org/download.html#past-releases) 8.2.1, [SFCGAL](http://sfcgal.org) support (1.4.1), address_standardizer, topology
   * PostGIS Tiger geocoder extension - Tiger 2022
-  * pgRouting 3.4 [pgRouting 3.4.2](https://docs.pgrouting.org/3.4/en/index.html)
+  * pgRouting 3.5 [pgRouting 3.5.0](https://docs.pgrouting.org/3.5/en/index.html)
   * Commandline raster loader (raster2pgsql), shapefile import/export (shp2pgsql,pgsql2shp)
   * Commandline [osm2pgrouting 2.3.8](https://github.com/pgRouting/osm2pgrouting/wiki/Documentation-for-osm2pgrouting-v2.3) for loading data from .osm files into pgRouting routable format
   * GUI: shp2pgsql-gui which has both import and export support for geometry/geography
@@ -30,11 +27,13 @@ PostGIS 3.3.2 bundle includes:
 		reading both spatial (spatial columns become postgis geometry) and non-spatial data.    [IMPORT FOREIGN SCHEMA](http://www.postgresonline.com/journal/archives/359-Import-Foreign-Schema-for-ogr_fdw-for-PostgreSQL-9.5.html) support
     New features in 1.1 - `character_encoding` option and utility functions `ogr_fdw_drivers()`, `ogr_fdw_version()`
-  * [GDAL 3.4.3](https://gdal.org/download.html#current-releases) with OpenJPEG 2.4.0 (JPEG 2000), ODBC, Curl, SQLite3 (for GeoPackage and OSM support), excel (XLS) (via FreeXL 1.0.6), libreoffice, XLSX spreadsheet (via expat)  (used by both PostGIS raster and ogrfdw)
+  * [GDAL 3.6.4](https://gdal.org/download.html#current-releases) with OpenJPEG 2.4.0 (JPEG 2000), ODBC, Curl, SQLite3 (for GeoPackage and OSM support), excel (XLS) (via FreeXL 1.0.6), libreoffice, XLSX spreadsheet (via expat)  (used by both PostGIS raster and ogrfdw)
   * [pgpointcloud](https://github.com/pgpointcloud/pointcloud) 1.2.4
     for querying LIDAR point cloud and in/out functions to convert to PostGIS geometry
-  * [h3-pg](https://github.com/zachasme/h3-pg) 4.0.3 - this is the first PostGIS Bundle to include this feature
+  * [h3-pg](https://github.com/zachasme/h3-pg) 4.0.3
     for using Uber h3 api and converting h3 index representations to postgis geometry/geography.
+  * [MobilityDB](https://mobilitydb.com) [develop branch 1.1 66849fed01](https://github.com/MobilityDB/MobilityDB/tree/66849fed01)
+    for managing trajectories.  Includes many temporal spatial types and functions for them. Refer to [Enabling PostGIS Extensions: MobilityDb](../enabling_postgis/#mobilitydb) for guidance.
 The simplest way to get PostGIS on Windows for the EnterpriseDb Windows PostgreSQL distribution is using the StackBuilder.
Summary of changes:
 .../install_windows/enabling_postgis.md            | 12 ++++++++---
 .../install_windows/released_versions.md           | 23 +++++++++++-----------
 2 files changed, 20 insertions(+), 15 deletions(-)
hooks/post-receive
postgis.net
