[postgis-tickets] [PostGIS] #5370: bessie regress failures on raster after upgrade to GDAL 3.6.1 and Proj 9.2.0
PostGIS trac at osgeo.org
Fri Jun 2 02:31:38 PDT 2023
9.2.0
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.4.0
 Component:  buildbots  |    Version:  3.3.x
Resolution:             |   Keywords:
Comment (by lbartoletti):
 Did you use quarterly or latest for pkg? Cf /etc/pkg/FreeBSD.conf
 To enable latest:
 mkdir -p /usr/local/etc/pkg/repos
 echo "FreeBSD: { enabled: no }" > /usr/local/etc/pkg/repos/FreeBSD.conf
 sed -e "s/quarterly/latest/" /etc/pkg/FreeBSD.conf >
 /usr/local/etc/pkg/repos/FreeBSD_latest.conf
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5370#comment:4>
