[postgis-tickets] [PostGIS] #5370: bessie regress failures on raster after upgrade to GDAL 3.6.1 and Proj 9.2.0
PostGIS trac at osgeo.org
Tue Jun 20 13:15:47 PDT 2023
9.2.0
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.4.0
 Component:  buildbots  |    Version:  3.3.x
Resolution:             |   Keywords:
Comment (by robe):
 @lbartoletti
 Sorry didn't see your note until I did some more things.
 But I think it's all resolved now.
 My /usr/local/etc/pkg/repos/FreeBSD.conf
 looks like:
 FreeBSD: {
   url: "pkg+http://pkg.FreeBSD.org/${ABI}/quarterly",
   mirror_type: "srv",
   signature_type: "fingerprints",
   fingerprints: "/usr/share/keys/pkg",
   enabled: yes
 I used ports instead
 portsnap fetch extract #first time
 # there after
 portsnap fetch update
 export ALLOW_UNSUPPORTED_SYSTEM=yes
 cd /usr/ports/graphics/gdal/ && make install clean
 make config # to change options
 And unchecked some of the things like MySQL, ODBC etc,  just keeping the
 basics.
 That seemed to work fine and gave me GDAL 3.7.1
 Last run of 3.2 branch looked good and had the below.  I'm going to
 renable raster testing on bessie now on the 3.3 and master that I had
 disabled it on.
 llvmorg-13.0.0-0-gd7b669b3a303), 64-bit
 12:53:15   Postgis 3.2.6dev - (59a8f9d) - 2023-06-20 16:49:51
 12:53:15   scripts 3.2.6dev 59a8f9d
 12:53:15   raster scripts 3.2.6dev 59a8f9d
 12:53:15   GEOS: 3.11.1-CAPI-1.17.1
 12:53:15   PROJ: 9.2.0
 12:53:15   SFCGAL: 1.4.1
 12:53:15   GDAL: GDAL 3.7.0, released 2023/05/02
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5370#comment:5>
