[postgis-tickets] [PostGIS] #5344: Restoring extension based topology dump fails resetting the topology sequence
PostGIS trac at osgeo.org
Fri Jun 2 04:49:35 PDT 2023
sequence
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 3.0.9
 Component:  topology  |    Version:  master
Resolution:  fixed     |   Keywords:
Comment (by strk):
 This change introduced a regression with pg_dump, see #5395
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5344#comment:12>
