[postgis-tickets] [PostGIS] #5344: Restoring extension based topology dump fails resetting the topology sequence
PostGIS trac at osgeo.org
Mon Jun 5 08:54:34 PDT 2023
sequence
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 3.0.9
 Component:  topology  |    Version:  master
Resolution:  fixed     |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"6f8b43f882ed24d7800a175c9fd863612e793736/git" 6f8b43f/git]:
 {{{#!CommitTicketReference repository="git"
 revision="6f8b43f882ed24d7800a175c9fd863612e793736"
 Grant select on topology sequences
 Allows public dumping of postgis-topology enabled database
 (as long as there are no topologies)
 References #5344 in master branch (3.4.0dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5344#comment:13>
