[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-963-g5e05bc3e7
Mon Jun 5 08:54:24 PDT 2023
the project "PostGIS".
       via  5e05bc3e7461e19055f16af367c6fc9260222179 (commit)
       via  6f8b43f882ed24d7800a175c9fd863612e793736 (commit)
      from  f534ee90efe82f3393c0278fd596704ee14b52b3 (commit)
revisions in full, below.
commit 5e05bc3e7461e19055f16af367c6fc9260222179
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jun 5 17:52:17 2023 +0200
    Have skip signature generator scan full postgis upgrade script
    References #5396 in master branch (3.4.0dev)
diff --git a/utils/Makefile.in b/utils/Makefile.in
index 87d5be4ef..774724402 100644
--- a/utils/Makefile.in
+++ b/utils/Makefile.in
@@ -45,12 +45,11 @@ all: $(SCRIPTS_built)
 DROP_FILES = \
 	$(top_srcdir)/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in \
 	$(top_srcdir)/raster/rt_pg/rtpostgis_drop.sql.in \
-	$(top_srcdir)/postgis/postgis_after_upgrade.sql \
-	$(top_srcdir)/postgis/postgis_before_upgrade.sql \
 	$(top_srcdir)/topology/topology_after_upgrade.sql.in \
 	$(top_srcdir)/topology/topology_before_upgrade.sql.in \
 	$(top_builddir)/postgis/uninstall_postgis.sql \
 	$(top_builddir)/postgis/uninstall_legacy.sql \
+	$(top_builddir)/postgis/postgis_upgrade.sql \
 	$(top_builddir)/sfcgal/uninstall_sfcgal.sql \
 	$(top_builddir)/raster/rt_pg/uninstall_rtpostgis.sql \
 	$(top_builddir)/topology/uninstall_topology.sql
commit 6f8b43f882ed24d7800a175c9fd863612e793736
Date:   Mon Jun 5 17:42:41 2023 +0200
    Grant select on topology sequences
    Allows public dumping of postgis-topology enabled database
    (as long as there are no topologies)
    References #5344 in master branch (3.4.0dev)
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index b8f05d9da..ef89fdaeb 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1466,5 +1466,7 @@ GRANT SELECT ON topology.topology TO PUBLIC;
 GRANT SELECT ON topology.layer TO PUBLIC;
 -- See https://trac.osgeo.org/postgis/ticket/5124
 GRANT USAGE ON SCHEMA topology TO PUBLIC;
+-- See https://trac.osgeo.org/postgis/ticket/5395
+GRANT SELECT ON ALL SEQUENCES IN SCHEMA topology TO PUBLIC;
 COMMIT;
Summary of changes:
 topology/topology.sql.in | 2 ++
 utils/Makefile.in        | 3 +--
 2 files changed, 3 insertions(+), 2 deletions(-)
hooks/post-receive
