[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-971-g123a3dc75
git at osgeo.org
git at osgeo.org
Thu Jun 15 14:45:27 PDT 2023
the project "PostGIS".
via 123a3dc7532c3fcc94f399153f0618ab1027fa5a (commit)
from 3f57ca3d251a41a0d2aab944ce75a4a526c08c88 (commit)
revisions in full, below.
commit 123a3dc7532c3fcc94f399153f0618ab1027fa5a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Jun 15 14:44:46 2023 -0700
Only test projections that use a WGS84 GEOGCS to avoid
exercising the grid shift system in this test.
References #5316
diff --git a/regress/core/regress_proj_cache_overflow.sql b/regress/core/regress_proj_cache_overflow.sql
index c404effe8..ea7b36aa5 100644
--- a/regress/core/regress_proj_cache_overflow.sql
+++ b/regress/core/regress_proj_cache_overflow.sql
@@ -1,7 +1,12 @@
--- Overflow proj cache
SELECT 13, count(*) FROM
- SELECT ST_Transform('SRID=4326; POINT(0 0)'::geometry, srid) AS g
- FROM
- ( Select srid from spatial_ref_sys where srid IN (3819, 3821, 3824, 3889, 3906, 4001, 4002, 4003, 4004, 4005, 4006, 4007, 4008, 4009, 4010, 4011, 4012, 4013, 4014, 4015, 4016, 4018, 4019, 4020, 4021, 4022, 4023, 4024, 4025, 4027, 4028, 4029, 4030, 4031, 4032, 4033, 4034, 4035, 4036, 4041, 4042, 4043, 4044, 4045, 4046, 4047, 4052, 4053, 4054, 4055, 4075, 4081, 4120, 4121, 4122, 4123, 4124, 4125, 4126, 4127, 4128, 4129, 4130, 4131, 4132, 4133, 4134, 4135, 4139, 4140, 4141, 4142, 4143, 4144, 4145, 4146, 4147, 4148, 4149, 4150, 4151, 4152, 4153, 4154, 4155, 4156, 4157, 4158, 4159, 4160, 4161, 4162, 4163, 4164, 4165, 4166, 4167, 4168, 4169, 4170, 4171, 4172, 4173, 4174, 4175, 4176, 4178, 4179, 4180, 4181, 4182, 4183, 4184, 4185, 4188, 4189, 4190, 4191, 4192, 4193, 4194, 4195, 4196, 4197, 4198, 4199, 4200, 4201, 4202, 4203, 4204, 4205, 4206, 4207, 4
208, 4209, 4210, 4211, 4212, 4213, 4214, 4215, 4216, 4218, 4219, 4220, 4221)) _a
-) _b WHERE g IS NOT NULL;
+ SELECT ST_Transform('SRID=4326; POINT(0 0)'::geometry, srid) AS g
+ FROM (
+ SELECT srid
+ FROM spatial_ref_sys
+ WHERE srid IN (
+ 2309, 2310, 2311, 3031, 3573, 3574, 3032, 3033, 3575, 4037, 3204, 3205, 3206, 3207, 3208, 3209, 3210, 3211, 3212, 3213, 3214, 3215, 3216, 3217, 3218, 3219, 3220, 3221, 3222, 3223, 3224, 3225, 3226, 3227, 3228, 3229, 3230, 3231, 3232, 3233, 3234, 3235, 3236, 3237, 3238, 3239, 3240, 3241, 3242, 3243, 3244, 3245, 3246, 3247, 3248, 3249, 3250, 3251, 3252, 3253, 3254, 3255, 3256, 3257, 3258, 3259, 3260, 3261, 3262, 3263, 3264, 3265, 3266, 3267, 3268, 3269, 3270, 3271, 3272, 3273, 3274, 3275, 3276, 3277, 3278, 3279, 3280, 3281, 3282, 3283, 3284, 3285, 3286, 3287, 3288, 3289, 3290, 3291, 3292, 3293, 3294, 3349, 4038, 3413, 3395, 3576, 3571, 3572, 3752, 3762, 3974, 3832, 3857, 3975, 3973, 3976, 3994, 3995, 3996, 3997, 4087, 4326, 4462, 4826, 5041, 5042, 5223, 5523, 5842, 5921, 5922, 5923, 5924, 5925, 5926, 5927, 5928, 5929, 5930, 5931, 5932, 5933, 5934, 5935, 5936, 5937, 5938
+ )) _a
+) _b
+WHERE g IS NOT NULL;
Summary of changes:
regress/core/regress_proj_cache_overflow.sql | 13 +++++++++----
1 file changed, 9 insertions(+), 4 deletions(-)
hooks/post-receive
