[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-972-g8587a621d
Thu Jun 15 14:51:33 PDT 2023
the project "PostGIS".
       via  8587a621dbc928841e2ba4f932b3f3acf272a6e9 (commit)
      from  123a3dc7532c3fcc94f399153f0618ab1027fa5a (commit)
revisions in full, below.
commit 8587a621dbc928841e2ba4f932b3f3acf272a6e9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jun 15 14:51:03 2023 -0700
    Change test to harmonize GEOGCS entries and hopefully
    avoid exercising the Proj gridshift system.
    References #5316
diff --git a/regress/core/regress_proj_4890.sql b/regress/core/regress_proj_4890.sql
index 297c1ef3b..4f9528c42 100644
--- a/regress/core/regress_proj_4890.sql
+++ b/regress/core/regress_proj_4890.sql
@@ -1,12 +1,43 @@
-CREATE TABLE points AS SELECT * FROM (VALUES ('SRID=4326;POINT(-124.9921 49.6851)'::geometry), ('SRID=4326;POINT(-119.4032 50.0305)'::geometry), ('SRID=4326;POINT(-122.799 49.1671)'::geometry), ('SRID=4326;POINT(-122.3379 49.0597)'::geometry), ('SRID=4326;POINT(-123.1264 49.2671)'::geometry), ('SRID=4326;POINT(-122.7132 49.0519)'::geometry), ('SRID=4326;POINT(-124.3475 49.3042)'::geometry), ('SRID=4326;POINT(-119.389 49.8891)'::geometry), ('SRID=4326;POINT(-123.126 49.281)'::geometry), ('SRID=4326;POINT(-122.6606 49.1134)'::geometry), ('SRID=4326;POINT(-124.3233 49.312)'::geometry), ('SRID=4326;POINT(-124.0478 49.2397)'::geometry), ('SRID=4326;POINT(-119.2683 50.266)'::geometry), ('SRID=4326;POINT(-121.9705 49.081)'::geometry), ('SRID=4326;POINT(-123.8854 49.482)'::geometry), ('SRID=4326;POINT(-123.1528 49.77)'::geometry), ('SRID=4326;POINT(-120.8051 50.488)'::geometry), ('SRID=4326;POINT(-122.6403 49.1652)'::geometry), ('SRID=4326;POINT(-122.7717 49.2433)'::geometry), ('SRID=4326;P
 OINT(-121.9587 49.1661)'::geometry))
-p(g);
+CREATE TABLE points AS
+	SELECT * FROM (
+		VALUES
+			('SRID=4269;POINT(-124.9921 49.6851)'::geometry),
+			('SRID=4269;POINT(-119.4032 50.0305)'::geometry),
+			('SRID=4269;POINT(-122.799 49.1671)'::geometry),
+			('SRID=4269;POINT(-122.3379 49.0597)'::geometry),
+			('SRID=4269;POINT(-123.1264 49.2671)'::geometry),
+			('SRID=4269;POINT(-122.7132 49.0519)'::geometry),
+			('SRID=4269;POINT(-124.3475 49.3042)'::geometry),
+			('SRID=4269;POINT(-119.389 49.8891)'::geometry),
+			('SRID=4269;POINT(-123.126 49.281)'::geometry),
+			('SRID=4269;POINT(-122.6606 49.1134)'::geometry),
+			('SRID=4269;POINT(-124.3233 49.312)'::geometry),
+			('SRID=4269;POINT(-124.0478 49.2397)'::geometry),
+			('SRID=4269;POINT(-119.2683 50.266)'::geometry),
+			('SRID=4269;POINT(-121.9705 49.081)'::geometry),
+			('SRID=4269;POINT(-123.8854 49.482)'::geometry),
+			('SRID=4269;POINT(-123.1528 49.77)'::geometry),
+			('SRID=4269;POINT(-120.8051 50.488)'::geometry),
+			('SRID=4269;POINT(-122.6403 49.1652)'::geometry),
+			('SRID=4269;POINT(-122.7717 49.2433)'::geometry),
+			('SRID=4269;POINT(-121.9587 49.1661)'::geometry)
+		) p(g);
-CREATE OR REPLACE FUNCTION get_closest(p geometry(POINT)) RETURNS geometry(POINT) AS $$
-    SELECT g FROM points ORDER BY st_transform(p, 3005) <-> st_transform(points.g, 3005) LIMIT 1
-STABLE
-LANGUAGE SQL;
+CREATE OR REPLACE FUNCTION get_closest(p geometry(POINT))
+	RETURNS geometry(POINT)
+	AS
+		SELECT g
+		FROM points
+		ORDER BY st_transform(p, 3005) <-> st_transform(points.g, 3005)
+		LIMIT 1
+	STABLE
+	LANGUAGE SQL;
+SELECT 4890 AS id,
+			 ST_AsText(ST_SnapToGrid(ST_Centroid(ST_Collect(get_closest(g) )), 0.0001))
+	FROM points;
-SELECT 4890 AS id, ST_AsText(ST_SnapToGrid(ST_Centroid(ST_Collect(get_closest(g) )), 0.0001)) FROM points ;
 DROP TABLE points;
 DROP FUNCTION get_closest(geometry);
Summary of changes:
 regress/core/regress_proj_4890.sql | 47 +++++++++++++++++++++++++++++++-------
 1 file changed, 39 insertions(+), 8 deletions(-)
hooks/post-receive
