[postgis-tickets] [SCM] postgis.net branch website updated. clarity-final-31-g575dd0e
git at osgeo.org
git at osgeo.org
Sat Jun 17 10:02:49 PDT 2023
the project "postgis.net".
The branch, website has been updated
via 575dd0e57988781741ba0e07a29ec6f3db91866b (commit)
from b1d67ff6ca02e3aec96c50696c5a3440e18a0bbc (commit)
revisions in full, below.
commit 575dd0e57988781741ba0e07a29ec6f3db91866b
Author: Regina Obe <lr at pcorp.us>
Date: Sat Jun 17 13:02:42 2023 -0400
Fix typo
diff --git a/content/documentation/faq/gpl-license.md b/content/documentation/faq/gpl-license.md
index 066c939..0012e14 100644
--- a/content/documentation/faq/gpl-license.md
+++ b/content/documentation/faq/gpl-license.md
@@ -9,7 +9,7 @@ tags: [licensing]
PostGIS is open source software available under the [GNU GPLv2](https://www.gnu.org/licenses/old-licenses/gpl-2.0.en.html). While the GPL does have some expansive "share and share alike" clauses in it, they **do not apply** to the ordinary uses people make of a spatial database, such as loading data into it and running queries against it.
-If you are releasing software that uses PostGIS, does that mean your software has to be licensed using the GPL like PostGIS? Will your have to publish all your code if your use PostGIS?
+If you are releasing software that uses PostGIS, does that mean your software has to be licensed using the GPL like PostGIS? Will you have to publish all your code if your use PostGIS?
Almost certainly **not**. As an example, consider an Oracle database running on Linux. Linux is GPL, Oracle is not: does Oracle running on Linux have to be distributed using the GPL? No. Similarly your software can use a PostgreSQL/PostGIS database as much as it wants and be under any license you like.
Summary of changes:
content/documentation/faq/gpl-license.md | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
postgis.net
