[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-980-gc055f1acd
Sat Jun 17 20:46:10 PDT 2023
the project "PostGIS".
       via  c055f1acdd1af5a03408c1b67743abc3b4bdf7a8 (commit)
      from  b0388921dcea093d370fddc45b3259610f34153a (commit)
revisions in full, below.
commit c055f1acdd1af5a03408c1b67743abc3b4bdf7a8
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Jun 17 23:38:09 2023 -0400
    FIX GHA clang failures for clang  14
    - remove  explicit conversion, seems to cause clang 14 to fail
    - base path of LD_PRELOAD based on major version of clang
      instead of hard-coded 11
    Closes #5400
diff --git a/ci/github/run_usan_clang.sh b/ci/github/run_usan_clang.sh
index 70652ba0b..296c44ffc 100644
--- a/ci/github/run_usan_clang.sh
+++ b/ci/github/run_usan_clang.sh
@@ -1,8 +1,12 @@
 #!/usr/bin/env bash
 set -e
+CLANG_FULL_VER=`clang --version`
+echo $CLANG_FULL_VER
+echo `cat /etc/os-release`
+export CLANG_VER=`clang --version | perl -lne 'print $1 if /version (\d+)/'`
+echo "Clang major version is: $CLANG_VER"
 # Enable undefined behaviour sanitizer using traps
-CFLAGS_USAN="-g3 -O0 -mtune=generic -fno-omit-frame-pointer -fsanitize=undefined,implicit-conversion -fsanitize-undefined-trap-on-error -fno-sanitize-recover=implicit-conversion"
+CFLAGS_USAN="-g3 -O0 -mtune=generic -fno-omit-frame-pointer -fsanitize=undefined -fsanitize-undefined-trap-on-error -fno-sanitize-recover"
 LDFLAGS_STD="-Wl,-Bsymbolic-functions -Wl,-z,relro"
 # Sanitizer options to continue avoid stopping the runs on leaks (expected on postgres binaries)
@@ -10,7 +14,8 @@ export ASAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
 export MSAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
 #Run postgres preloading sanitizer libs
-LD_PRELOAD=/usr/lib/clang/11/lib/linux/libclang_rt.asan-x86_64.so \
+LD_PRELOAD=/usr/lib/clang/${CLANG_VER}/lib/linux/libclang_rt.asan-x86_64.so
 /usr/local/pgsql/bin/pg_ctl -c -o '-F' -l /tmp/logfile start
Summary of changes:
 ci/github/run_usan_clang.sh | 11 ++++++++---
 1 file changed, 8 insertions(+), 3 deletions(-)
hooks/post-receive
