[postgis-tickets] [PostGIS] #5404: debbie failing on tickets regress ST_DistanceCPA PostGIS 3.1, GEOS 3.9 branch
PostGIS trac at osgeo.org
Mon Jun 19 05:49:46 PDT 2023
branch
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.1.10
 Component:  buildbots  |    Version:  3.1.x
Resolution:             |   Keywords:
Comment (by robe):
 I should add the same failure is happening on debbie's, PostGIS 3.2 branch
 which tests against  GEOS: 3.10.6dev-CAPI-1.16.3.
 but it's not failing on PostGIS 3.3 branch which is testing GEOS: 3.11
 .3dev-CAPI-1.17
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5404#comment:1>
