[postgis-tickets] [PostGIS] #5404: debbie failing on tickets regress ST_DistanceCPA PostGIS 3.1, GEOS 3.9 branch
PostGIS trac at osgeo.org
Mon Jun 19 07:33:50 PDT 2023
branch
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.1.10
 Component:  buildbots  |    Version:  3.1.x
Resolution:             |   Keywords:
Comment (by strk):
 Those failing tests are referencing ticket #4037 which was calling for
 auto-fix of invalid polygons, and did expect a return from those calls,
 but later the behaviour changed referencing #4040 -- all in all I'm ok
 with dropping the tests all togheter, and in general I think tests are
 better put in a file naming the operation rather than in "tickets.sql"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5404#comment:2>
