[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1000-g8cebf5d6f
Thu Jun 22 19:56:49 PDT 2023
the project "PostGIS".
       via  8cebf5d6fc07e0dbfdb104a37ea5163dc1723877 (commit)
      from  0583468045bf125e6248f271f04405f46a64664e (commit)
revisions in full, below.
commit 8cebf5d6fc07e0dbfdb104a37ea5163dc1723877
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Jun 22 21:00:32 2023 -0400
    CHANGES for debug_standardize_address
    References #5397
     - Add tests for debug_standardize_address
     - Try to fix gitlab complaints
     - Turn back on address_standardizer testing on winnie
     - Fix postgis_tiger_geocoder regress not working. References #5254
     - Turn back on winnie postgis_tiger_geocoder regression
       (it's going to fail because of #5408)
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 163eba6a1..682fe17bb 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -241,16 +241,15 @@ done
  make check RUNTESTFLAGS="--extension -v"
-## TODO: Put back after folder into main check setup #5254
- ##test address standardizer
- #cd ${POSTGIS_SRC}
- #cd extensions/address_standardizer
- #make installcheck
- ##test tiger geocoder
- #cd extensions/postgis_tiger_geocoder
+ #test address standardizer
+ cd ${POSTGIS_SRC}
+ cd extensions/address_standardizer
+ make installcheck
+ #test tiger geocoder
+ cd ${POSTGIS_SRC}
+ cd extensions/postgis_tiger_geocoder
+ make installcheck
  if [ "$?" != "0" ]; then
   exit $?
  fi
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index a13ca6358..8b07ad87e 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -50,15 +50,14 @@ DATA_built = \
 all:  sql/address_standardizer_pre.sql sql/address_standardizer.sql sql/address_standardizer--1.0--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql \
  sql/$(EXTENSION)_data_us.sql sql/address_standardizer-- at POSTGIS_LIB_VERSION@.sql sql/$(EXTENSION)_data_us-- at POSTGIS_LIB_VERSION@.sql  sql/$(EXTENSION)_data_us--$(EXTVERSION)--$(EXTVERSION)next.sql \
 sql/$(EXTENSION)_data_us--$(EXTVERSION)next--$(EXTVERSION).sql sql/$(EXTENSION)_data_us--ANY--$(EXTVERSION).sql \
-sql/test-init-extensions.sql sql/test-parseaddress.sql sql/test-standardize_address_1.sql sql/test-standardize_address_2.sql
+sql/test-init-extensions.sql sql/test-parseaddress.sql sql/test-standardize_address_1.sql sql/test-standardize_address_2.sql sql/test-debug_standardize_address.sql
 DOCS = README.address_standardizer
 PG_CPPFLAGS = @CFLAGS@ @CPPFLAGS@ -DPCRE_VERSION=@PCRE_VERSION@
 SHLIB_LINK = @SHLIB_LINK@ @PCRE_LDFLAGS@
 EXTRA_CLEAN = sql/ usps-st-city-name.txt mk-st-regexp mk-city-regex test_main
-REGRESS = test-init-extensions test-parseaddress test-standardize_address_1 test-standardize_address_2
+REGRESS = test-init-extensions test-parseaddress test-standardize_address_1 test-standardize_address_2 test-debug_standardize_address
 sql:
 	mkdir -p $@
diff --git a/extensions/address_standardizer/address_standardizer.c b/extensions/address_standardizer/address_standardizer.c
index 2a13d6406..a0a78f59f 100644
--- a/extensions/address_standardizer/address_standardizer.c
+++ b/extensions/address_standardizer/address_standardizer.c
@@ -151,9 +151,10 @@ debug_standardize_address(PG_FUNCTION_ARGS)
 	appendStringInfo(result, "%s", quote_identifier(macro));
 	appendStringInfoString(result, ",");
-    std = GetStdUsingFCInfo(fcinfo, lextab, gaztab, rultab);
-    if (!std)
-        elog(ERROR, "%s failed to create the address standardizer object!",  __func__);
+	std = GetStdUsingFCInfo(fcinfo, lextab, gaztab, rultab);
+	if (!std){
+		elog(ERROR, "%s failed to create the address standardizer object!",  __func__);
 	elog(DEBUG2, "%s: calling std_standardize_mm('%s', '%s')", __func__ , micro, macro);
     stdaddr = std_standardize_mm( std, micro, macro, 0 );
diff --git a/extensions/address_standardizer/expected/test-debug_standardize_address.out b/extensions/address_standardizer/expected/test-debug_standardize_address.out
new file mode 100644
index 000000000..31f312258
--- /dev/null
+++ b/extensions/address_standardizer/expected/test-debug_standardize_address.out
@@ -0,0 +1,39 @@
+SELECT je->>'pos' AS pos, je->>'input-word' AS input_word, je->>'input-token' AS input_token, je->>'mapped-word' AS ouput_word, je->>'output-token' AS output_token FROM jsonb(debug_standardize_address('us_lex'::text, 'us_gaz'::text, 'us_rules'::text, '123 Main Street'::text, 'Kansas City, MO 45678'::text)) AS d, jsonb_array_elements(d->'rules'->0->'rule_tokens' ) AS je;
+ pos | input_word | input_token | ouput_word | output_token
+ 0   | 123        | NUMBER      | 123        | HOUSE
+ 1   | MAIN       | WORD        | MAIN       | STREET
+ 2   | STREET     | TYPE        | STREET     | SUFTYP
+(3 rows)
+SELECT jsonb_array_length(jsonb(d)->'rules') FROM debug_standardize_address('us_lex','us_gaz','us_rules', '10-20 DORRANCE ST PROVIDENCE RI') AS d;
+ jsonb_array_length
+                  6
+(1 row)
+SELECT '#5299a' AS ticket, jsonb_array_length(d->'rules') AS num_rules, jsonb_array_length(d->'input_tokens') AS num_input_tokens,  d->'rules'->0->'raw_score' AS best_score FROM jsonb(debug_standardize_address('us_lex',  'us_gaz', 'us_rules','1 Timepiece Point','Boston, MA, 02220')) As d;
+ ticket | num_rules | num_input_tokens | best_score
+ #5299a |         5 |                4 | 0.902500
+(1 row)
+SELECT '#2978c' As ticket, , jsonb_array_length(d->'rules') AS num_rules, jsonb_array_length(d->'input_tokens') AS num_input_tokens,  d->'rules'->0->'raw_score' AS best_score FROM jsonb(debug_standardize_address('us_lex','us_gaz','us_rules', '10-20 DORRANCE ST, PROVIDENCE, RI')) AS d;
+ERROR:  syntax error at or near ","
+LINE 1: SELECT '#2978c' As ticket, , jsonb_array_length(d->'rules') ...
+SELECT '#5299b' AS ticket, jsonb_array_length(d->'rules') AS num_rules, jsonb_array_length(d->'input_tokens') AS num_input_tokens, d->'rules'->0->'score' AS best_score FROM jsonb(debug_standardize_address('us_lex',  'us_gaz', 'us_rules','50 Gold Piece Drive, Boston, MA, 02020')) AS d;
+ #5299b |         3 |                6 | 0.902500
+(1 row)
+SELECT '#5299bt' AS ticket, it->>'pos' AS pos, it->>'word' AS word,  it->>'token' AS token, it->>'stdword' AS stdword FROM jsonb(debug_standardize_address('us_lex',  'us_gaz', 'us_rules','50 Gold Piece Drive, Boston, MA, 02020')) AS d, jsonb_array_elements(d->'input_tokens') AS it
+WHERE it @> '{"pos": 2}'::jsonb;
+ ticket  | pos | word  | token | stdword
+ #5299bt | 2   | PIECE | UNITH | PIECE
+ #5299bt | 2   | PIECE | UNITT | PIECE
+ #5299bt | 2   | PIECE | WORD  | PIECE
+(3 rows)
diff --git a/extensions/address_standardizer/test-debug_standardize_address.sql.in b/extensions/address_standardizer/test-debug_standardize_address.sql.in
index 000000000..fc8f7fcbb
--- /dev/null
+++ b/extensions/address_standardizer/test-debug_standardize_address.sql.in
@@ -0,0 +1,11 @@
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index 8c7df1532..ed0fd3c08 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -63,7 +63,7 @@ sql/test-normalize_address.sql: sql_bits/test_tuples_only_unaligned.sql.in ../..
 	cat $^ > $@
 sql/test-upgrade.sql: | sql
-	echo 'ALTER EXTENSION ${EXTENSION} UPDATE TO "$(EXTVERSION)next"' > $@
+	echo 'ALTER EXTENSION ${EXTENSION} UPDATE TO "ANY"; ALTER EXTENSION ${EXTENSION} UPDATE TO "$(EXTVERSION)"' > $@
 %.control: %.control.in Makefile
 	cat $< \
@@ -218,5 +218,4 @@ PERL=@PERL@
 VPATH = @srcdir@
 top_srcdir = @top_srcdir@
-top_builddir = @top_builddir@
 abs_topbuilddir=$(abspath $(top_builddir))
diff --git a/extensions/postgis_tiger_geocoder/regression.diffs b/extensions/postgis_tiger_geocoder/regression.diffs
index 000000000..fd98f21cb
--- /dev/null
+++ b/extensions/postgis_tiger_geocoder/regression.diffs
@@ -0,0 +1,12 @@
+diff -w -U3 C:/ming64gcc81/projects/postgis/postgis-git/extensions/postgis_tiger_geocoder/expected/test-pagc_normalize_address.out C:/ming64gcc81/projects/postgis/postgis-git/extensions/postgis_tiger_geocoder/results/test-pagc_normalize_address.out
+--- C:/ming64gcc81/projects/postgis/postgis-git/extensions/postgis_tiger_geocoder/expected/test-pagc_normalize_address.out	2023-06-22 22:01:47.690311400 -0400
++++ C:/ming64gcc81/projects/postgis/postgis-git/extensions/postgis_tiger_geocoder/results/test-pagc_normalize_address.out	2023-06-22 22:03:25.945667700 -0400
+@@ -4,7 +4,7 @@
+ #1051a|212||3RD|AVE|N|STE 560|MINNEAPOLIS|MN|55401|t||212
+ #1051b|3937||43RD|AVE|S||MINNEAPOLIS|MN|55406|t||3937
+ #1051c|212|N|3RD|AVE|||MINNEAPOLIS|MN|55401|t||212
+-#1051d|212||3RD|AVE|||MINNEAPOLIS|MN|N 55401|t||212
++#1051d|212||3RD|AVE|N||MINNEAPOLIS|MN|55401|t||212
+ 529||MAIN|ST|||BOSTON|MA|02129|t||529
+ 529||MAIN|ST|||BOSTON|MA||t||529
diff --git a/extensions/postgis_tiger_geocoder/regression.out b/extensions/postgis_tiger_geocoder/regression.out
index 000000000..9354390a6
--- /dev/null
+++ b/extensions/postgis_tiger_geocoder/regression.out
@@ -0,0 +1,8 @@
+# using postmaster on localhost, port 5453
+ok 1         - test-normalize_address                    216 ms
+ok 2         - test-upgrade                              456 ms
+not ok 3     + test-pagc_normalize_address                 0 ms
+1..3
+# 1 of 3 tests failed.
+# The differences that caused some tests to fail can be viewed in the file "C:/ming64gcc81/projects/postgis/postgis-git/extensions/postgis_tiger_geocoder/regression.diffs".
+# A copy of the test summary that you see above is saved in the file "C:/ming64gcc81/projects/postgis/postgis-git/extensions/postgis_tiger_geocoder/regression.out".
Summary of changes:
 ci/winnie/regress_postgis.sh                       | 19 +++++------
 extensions/address_standardizer/Makefile.in        |  5 ++-
 .../address_standardizer/address_standardizer.c    |  7 ++--
 .../expected/test-debug_standardize_address.out    | 39 ++++++++++++++++++++++
 .../test-debug_standardize_address.sql.in          | 11 ++++++
 extensions/postgis_tiger_geocoder/Makefile.in      |  3 +-
 extensions/postgis_tiger_geocoder/regression.diffs | 12 +++++++
 extensions/postgis_tiger_geocoder/regression.out   |  8 +++++
 8 files changed, 86 insertions(+), 18 deletions(-)
 create mode 100644 extensions/address_standardizer/expected/test-debug_standardize_address.out
 create mode 100644 extensions/address_standardizer/test-debug_standardize_address.sql.in
 create mode 100644 extensions/postgis_tiger_geocoder/regression.diffs
 create mode 100644 extensions/postgis_tiger_geocoder/regression.out
hooks/post-receive
