[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1001-g7f823a67b
Thu Jun 22 20:00:00 PDT 2023
the project "PostGIS".
       via  7f823a67b77ed12f738aa260def6c24cebc23717 (commit)
      from  8cebf5d6fc07e0dbfdb104a37ea5163dc1723877 (commit)
revisions in full, below.
commit 7f823a67b77ed12f738aa260def6c24cebc23717
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Jun 22 22:59:56 2023 -0400
    Remove accidentally committed files. And mark these as ignore for future
diff --git a/.gitignore b/.gitignore
index 99dfaaeed..e77b20ce0 100644
--- a/.gitignore
+++ b/.gitignore
@@ -148,6 +148,8 @@ raster/test/Makefile
 raster/test/regress/Makefile
 raster/test/regress/rtpostgis.sql
 raster/test/regress/loader/TiledAutoSkipNoData.tif
+regression.diffs
+regession.out
 regress/00-regress-install/
 regress/Makefile
 regress/core/Makefile
diff --git a/extensions/postgis_tiger_geocoder/regression.diffs b/extensions/postgis_tiger_geocoder/regression.diffs
deleted file mode 100644
index fd98f21cb..000000000
--- a/extensions/postgis_tiger_geocoder/regression.diffs
+++ /dev/null
@@ -1,12 +0,0 @@
-diff -w -U3 C:/ming64gcc81/projects/postgis/postgis-git/extensions/postgis_tiger_geocoder/expected/test-pagc_normalize_address.out C:/ming64gcc81/projects/postgis/postgis-git/extensions/postgis_tiger_geocoder/results/test-pagc_normalize_address.out
---- C:/ming64gcc81/projects/postgis/postgis-git/extensions/postgis_tiger_geocoder/expected/test-pagc_normalize_address.out	2023-06-22 22:01:47.690311400 -0400
-+++ C:/ming64gcc81/projects/postgis/postgis-git/extensions/postgis_tiger_geocoder/results/test-pagc_normalize_address.out	2023-06-22 22:03:25.945667700 -0400
-@@ -4,7 +4,7 @@
- #1051a|212||3RD|AVE|N|STE 560|MINNEAPOLIS|MN|55401|t||212
- #1051b|3937||43RD|AVE|S||MINNEAPOLIS|MN|55406|t||3937
- #1051c|212|N|3RD|AVE|||MINNEAPOLIS|MN|55401|t||212
--#1051d|212||3RD|AVE|||MINNEAPOLIS|MN|N 55401|t||212
-+#1051d|212||3RD|AVE|N||MINNEAPOLIS|MN|55401|t||212
- 529||MAIN|ST|||BOSTON|MA|02129|t||529
- 529||MAIN|ST|||BOSTON|MA||t||529
diff --git a/extensions/postgis_tiger_geocoder/regression.out b/extensions/postgis_tiger_geocoder/regression.out
index 9354390a6..000000000
--- a/extensions/postgis_tiger_geocoder/regression.out
+++ /dev/null
@@ -1,8 +0,0 @@
-# using postmaster on localhost, port 5453
-ok 1         - test-normalize_address                    216 ms
-ok 2         - test-upgrade                              456 ms
-not ok 3     + test-pagc_normalize_address                 0 ms
-1..3
-# 1 of 3 tests failed.
-# The differences that caused some tests to fail can be viewed in the file "C:/ming64gcc81/projects/postgis/postgis-git/extensions/postgis_tiger_geocoder/regression.diffs".
-# A copy of the test summary that you see above is saved in the file "C:/ming64gcc81/projects/postgis/postgis-git/extensions/postgis_tiger_geocoder/regression.out".
Summary of changes:
 .gitignore                                         |  2 ++
 extensions/postgis_tiger_geocoder/regression.diffs | 12 ------------
 extensions/postgis_tiger_geocoder/regression.out   |  8 --------
 3 files changed, 2 insertions(+), 20 deletions(-)
 delete mode 100644 extensions/postgis_tiger_geocoder/regression.diffs
 delete mode 100644 extensions/postgis_tiger_geocoder/regression.out
hooks/post-receive
