[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1006-gee857ca70
Mon Jun 26 08:26:12 PDT 2023
the project "PostGIS".
       via  ee857ca7006d14c12c7700f8f2b05eb12e36e6ed (commit)
      from  6d4ef08fc7c9e5155d2515644a8f583aaca56609 (commit)
revisions in full, below.
commit ee857ca7006d14c12c7700f8f2b05eb12e36e6ed
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jun 26 17:24:58 2023 +0200
    Don't allow title tag to be the only in a sect2
    I'm not sure exactly why but this fixes documents checking for me.
    References #5411
diff --git a/doc/xsl/postgis_aggs_mm.xml.xsl b/doc/xsl/postgis_aggs_mm.xml.xsl
index bf2131f36..a92ea8787 100644
--- a/doc/xsl/postgis_aggs_mm.xml.xsl
+++ b/doc/xsl/postgis_aggs_mm.xml.xsl
@@ -1564,8 +1564,8 @@
 			<sect2 id="NewFunctions_1_5">
 				<title>PostGIS Functions new, behavior changed, or enhanced in 1.5</title>
-				<xsl:if test="//para[contains(text(),'Availability: 1.5')]">
 				<para>The functions given below are PostGIS functions that were introduced or enhanced in this minor release.</para>
+				<xsl:if test="//para[contains(text(),'Availability: 1.5')]">
 				<itemizedlist>
 				<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment  -->
 					<xsl:for-each select='//refentry'>
Summary of changes:
 doc/xsl/postgis_aggs_mm.xml.xsl | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
