[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1007-g4db6905eb
Mon Jun 26 09:09:25 PDT 2023
the project "PostGIS".
       via  4db6905ebed90ece2492a51a6e32beb48d6aab6a (commit)
      from  ee857ca7006d14c12c7700f8f2b05eb12e36e6ed (commit)
revisions in full, below.
commit 4db6905ebed90ece2492a51a6e32beb48d6aab6a
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jun 26 18:03:29 2023 +0200
    Improve robustness of postgis_aggs_mm.xml building rule
    Do not produce an empty file in case of failure,
    avoid potential circular dependency (strip entity before parse)
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 047a91104..8500fccc6 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -221,7 +221,8 @@ ifeq ($(XSLTPROC),)
 postgis_aggs_mm.xml: requirements_not_met_xsltproc
 else
 postgis_aggs_mm.xml: xsl/postgis_aggs_mm.xml.xsl Makefile postgis-out.xml $(XML_SOURCES)
-	$(XSLTPROC) --novalid --path $(srcdir) $< postgis-out.xml > $@
+	grep -v '\&postgis_aggs_mm;' postgis-out.xml | $(XSLTPROC) --novalid --path $(srcdir) $< - > $@.tmp
+	mv $@.tmp $@
 endif
 postgis_comments.sql: xsl/postgis_comments.sql.xsl $(XML_INPUTS)
@@ -355,6 +356,7 @@ clean:
 	rm -f $(XML_GENERATED_SOURCES)
 	rm -f postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
 	rm -f raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
+	rm -f *.tmp
 distclean: clean
 	$(MAKE) -C html/image_src distclean
Summary of changes:
 doc/Makefile.in | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
hooks/post-receive
