[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1015-g9401093fc
Tue Jun 27 09:45:45 PDT 2023
the project "PostGIS".
       via  9401093fc80073ae294d312a99be7338ceac7f66 (commit)
      from  503f99fcd4ad3119dd1ae206b841e710129e00f2 (commit)
revisions in full, below.
commit 9401093fc80073ae294d312a99be7338ceac7f66
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Jun 27 12:40:15 2023 -0400
    FIX GHA 16 latest warnings
    Closes #5278 for PostGIS 3.4.0
     - Turn back on warnings notices on latest (switch back tests mode)
     - Fix shadow warnings on gserialized gist c files
     - Fix shawow warning on mvt
     - Fix double-free warning on address_standardizer
     - Fix strncopy length depends on bounds of source instead of dest
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index a0614a2cd..c5dbf6498 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -27,7 +27,7 @@ jobs:
         - { tag: pg13-geos39-gdal31-proj71, mode: usan_gcc }
         - { tag: pg13-clang-geos39-gdal31-proj71, mode: usan_clang }
         # Run tests with different dependency combinations
-        - { tag: latest, mode: coverage }
+        - { tag: latest, mode: tests }
         - { tag: pg13-geos38-gdal31-proj71, mode: tests }
         - { tag: pg12-geos37-gdal30-proj611, mode: tests }
diff --git a/ci/github/run_tests.sh b/ci/github/run_tests.sh
index 63fe9948f..c7323f55b 100644
--- a/ci/github/run_tests.sh
+++ b/ci/github/run_tests.sh
@@ -2,7 +2,7 @@
 set -e
 WARNINGS="-Werror -Wall -Wextra -Wformat -Werror=format-security"
-WARNINGS_DISABLED="-Wno-unused-parameter -Wno-implicit-fallthrough -Wno-unknown-warning-option -Wno-cast-function-type"
+WARNINGS_DISABLED="-Wno-unused-parameter -Wno-implicit-fallthrough -Wno-cast-function-type"
 # Standard flags, as we might build PostGIS for production
 CFLAGS_STD="-g -O2 -mtune=generic -fno-omit-frame-pointer ${WARNINGS} ${WARNINGS_DISABLED}"
diff --git a/extensions/address_standardizer/gamma.c b/extensions/address_standardizer/gamma.c
index dcb16f7d0..413d957a9 100644
--- a/extensions/address_standardizer/gamma.c
+++ b/extensions/address_standardizer/gamma.c
@@ -162,7 +162,6 @@ RULES *rules_init( ERR_PARAM *err_p ) {
        rules -> Trie = NULL;
        rules_free(rules);
-       FREE_AND_NULL(rules);
        return NULL ;
diff --git a/loader/shp2pgsql-core.c b/loader/shp2pgsql-core.c
index 67e9eae00..a7a290c87 100644
--- a/loader/shp2pgsql-core.c
+++ b/loader/shp2pgsql-core.c
@@ -1173,9 +1173,10 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 		        ! strcmp(name, "oid") || ! strcmp(name, "ctid"))
 			size_t len = strlen(name);
-			if (len > (MAXFIELDNAMELEN - 2))
+			if (len > (MAXFIELDNAMELEN - 2)){
 				len = MAXFIELDNAMELEN - 2;
-			strncpy(name2 + 2, name, len);
+			strncpy(name2 + 2, name, MAXFIELDNAMELEN - 2);
 			name2[MAXFIELDNAMELEN-1] = '\0';
 			name2[len + 2] = '\0';
 			name2[0] = '_';
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index b39ef47b4..bc1983ff5 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -1722,7 +1722,6 @@ compute_gserialized_stats_mode(VacAttrStats *stats, AnalyzeAttrFetchFunc fetchfu
 		const ND_BOX *nd_box;
 		ND_IBOX nd_ibox;
 		int at[ND_DIMS];
-		int d;
 		double num_cells = 0;
 		double min[ND_DIMS] = {0.0, 0.0, 0.0, 0.0};
 		double max[ND_DIMS] = {0.0, 0.0, 0.0, 0.0};
diff --git a/postgis/gserialized_spgist_3d.c b/postgis/gserialized_spgist_3d.c
index dfdc8fc5d..9704fe831 100644
--- a/postgis/gserialized_spgist_3d.c
+++ b/postgis/gserialized_spgist_3d.c
@@ -424,6 +424,7 @@ PGDLLEXPORT Datum gserialized_spgist_picksplit_3d(PG_FUNCTION_ARGS)
 	spgPickSplitOut *out = (spgPickSplitOut *)PG_GETARG_POINTER(1);
 	BOX3D *centroid;
 	int median, i;
+	uint8 octant;
 	double *lowXs = palloc(sizeof(double) * in->nTuples);
 	double *highXs = palloc(sizeof(double) * in->nTuples);
 	double *lowYs = palloc(sizeof(double) * in->nTuples);
@@ -436,7 +437,7 @@ PGDLLEXPORT Datum gserialized_spgist_picksplit_3d(PG_FUNCTION_ARGS)
 	/* Calculate median of all 6D coordinates */
 	for (i = 0; i < in->nTuples; i++)
-		BOX3D *box = DatumGetBox3DP(in->datums[i]);
+		box = DatumGetBox3DP(in->datums[i]);
 		lowXs[i] = box->xmin;
 		highXs[i] = box->xmax;
@@ -481,8 +482,8 @@ PGDLLEXPORT Datum gserialized_spgist_picksplit_3d(PG_FUNCTION_ARGS)
-		uint8 octant = getOctant(centroid, box);
+		octant = getOctant(centroid, box);
 		out->leafTupleDatums[i] = Box3DPGetDatum(box);
 		out->mapTuplesToNodes[i] = octant;
diff --git a/postgis/gserialized_spgist_nd.c b/postgis/gserialized_spgist_nd.c
index 742478308..4dc417611 100644
--- a/postgis/gserialized_spgist_nd.c
+++ b/postgis/gserialized_spgist_nd.c
@@ -314,7 +314,7 @@ PGDLLEXPORT Datum gserialized_spgist_picksplit_nd(PG_FUNCTION_ARGS)
 	spgPickSplitIn *in = (spgPickSplitIn *)PG_GETARG_POINTER(0);
-	GIDX *box, *centroid;
+	GIDX *centroid;
 	float *lowXs, *highXs;
 	int ndims, maxdims = -1, count[GIDX_MAX_DIM], median, dim, tuple;
@@ -327,7 +327,7 @@ PGDLLEXPORT Datum gserialized_spgist_picksplit_nd(PG_FUNCTION_ARGS)
 	/* Calculate maxdims median of all ND coordinates */
 	for (tuple = 0; tuple < in->nTuples; tuple++)
-		box = (GIDX *)DatumGetPointer(in->datums[tuple]);
+		GIDX *box = (GIDX *)DatumGetPointer(in->datums[tuple]);
 		ndims = GIDX_NDIMS(box);
 		if (maxdims < ndims)
 			maxdims = ndims;
diff --git a/postgis/mvt.c b/postgis/mvt.c
index dc9426303..d35514952 100644
--- a/postgis/mvt.c
+++ b/postgis/mvt.c
@@ -1109,7 +1109,7 @@ static bytea *mvt_ctx_to_bytea(mvt_agg_context *ctx)
 	/* Zero features => empty bytea output */
 	if (ctx && ctx->layer && ctx->layer->n_features == 0)
-		bytea *ba = palloc(VARHDRSZ);
+		ba = palloc(VARHDRSZ);
 		SET_VARSIZE(ba, VARHDRSZ);
 		return ba;
Summary of changes:
 .github/workflows/ci.yml                | 2 +-
 ci/github/run_tests.sh                  | 2 +-
 extensions/address_standardizer/gamma.c | 1 -
 loader/shp2pgsql-core.c                 | 5 +++--
 postgis/gserialized_estimate.c          | 1 -
 postgis/gserialized_spgist_3d.c         | 7 ++++---
 postgis/gserialized_spgist_nd.c         | 4 ++--
 postgis/mvt.c                           | 2 +-
 8 files changed, 12 insertions(+), 12 deletions(-)
hooks/post-receive
