[postgis-tickets] [PostGIS] #5278: GHA PG16 tests failing on all warnings being treated as errors
PostGIS trac at osgeo.org
Tue Jun 27 12:23:33 PDT 2023
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"1985836e47d4566a978d0b298ae2a86b89b6b283/git" 1985836/git]:
 {{{#!CommitTicketReference repository="git"
 revision="1985836e47d4566a978d0b298ae2a86b89b6b283"
 Change local var names to avoid shadows, references #5278
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5278#comment:10>
