[postgis-tickets] [PostGIS] #5416: my local install is broken xsl issues
PostGIS trac at osgeo.org
Wed Jun 28 16:51:27 PDT 2023
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 I thought maybe it's just me, but I see the same issue on winnie
 xsl/table_body_function_support_matrix.xml.xsl -
 /projects/xsltproc/xsltproc --novalid --path .:./ent:. -o
 postgis_comments.sql xsl/postgis_comments.sql.xsl postgis-out.xml
 warning: failed to load external entity "ent/postgis_special.xml"
 postgis-out.xml:133: parser error : Failure to process entity
 postgis_special
   &postgis_special;
 postgis-out.xml:133: parser error : Entity 'postgis_special' not defined
   &postgis_special;
 Given the other ci bots are fine, might be some windows/mingw64 pathing
 issue
 What is that ./ent supposed to be doing?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5416>
