[postgis-tickets] [PostGIS] #5416: my local install is broken xsl issues
PostGIS trac at osgeo.org
Wed Jun 28 17:48:35 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 I think the issue was my xsltproc was just too old.
 I compiled xsltproc 1.1.38 (latest) version and things worked on my local.
 I've updated winnie's xsltproc as well as hers was just a copy of mine.
 Dated in 2009 (I know why fix something that isn't broke).
 I'll reopen this if winnie still has issues after.
 FWIW the 2009 version I had listed this for version:
 Using libxml 20707, libxslt 10126 and libexslt 815
 xsltproc was compiled against libxml 20706, libxslt 10126 and libexslt 815
 libxslt 10126 was compiled against libxml 20706
 libexslt 815 was compiled against libxml 20706
 The new one lists this
 Using libxml 20914, libxslt 10138 and libexslt 821
 xsltproc was compiled against libxml 20914, libxslt 10138 and libexslt 821
 libxslt 10138 was compiled against libxml 20914
 libexslt 821 was compiled against libxml 20914
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5416#comment:1>
