[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1054-gd91d4b4d8
Wed Jun 28 22:08:34 PDT 2023
the project "PostGIS".
       via  d91d4b4d8655eb7ba7832c09daf57902358233cc (commit)
       via  1eefd3e83d3e775a32bc22fcb98af3f78d7611ad (commit)
      from  c4d01ce30b1a9bd9e706c20db9afea31c295a71d (commit)
revisions in full, below.
commit d91d4b4d8655eb7ba7832c09daf57902358233cc
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Thu Jun 29 03:58:28 2023 +0000
    Translated postgis_special using Weblate (Japanese)
    Currently translated at 100.0% (55 of 55 strings)
    Translation: postgis/postgis_special
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis_special/ja/
diff --git a/doc/po/ja/postgis_special.xml.po b/doc/po/ja/postgis_special.xml.po
index 025335d5f..54c3170a3 100644
--- a/doc/po/ja/postgis_special.xml.po
+++ b/doc/po/ja/postgis_special.xml.po
@@ -1,31 +1,34 @@
 # Japanese translations for pg package.
 # Automatically generated, 2023.
+# Teramoto Ikuhiro <yellow at affrc.go.jp>, 2023.
 msgid ""
 msgstr ""
 "Project-Id-Version: pg 13\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-06-28 10:30+0000\n"
-"PO-Revision-Date: 2023-06-28 10:30+0000\n"
-"Last-Translator: Automatically generated\n"
-"Language-Team: none\n"
+"PO-Revision-Date: 2023-06-29 05:08+0000\n"
+"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"postgis_special/ja/>\n"
+"Language: ja\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Language: ja\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
+"X-Generator: Weblate 4.16.4\n"
 #. Tag: title
 #: postgis_special.xml:3
 #, no-c-format
 msgid "PostGIS Special Functions Index"
-msgstr ""
+msgstr "PostGIS関数索引"
 #. Tag: title
 #: postgis_special.xml:6
 #, no-c-format
 msgid "PostGIS Aggregate Functions"
-msgstr ""
+msgstr "PostGIS集約関数"
 #. Tag: para
 #: postgis_special.xml:7
@@ -35,18 +38,20 @@ msgid ""
 "same way as SQL aggregate function such as <code>sum</code> and "
 "<code>average</code>."
 msgstr ""
+"次に示す関数は、PostGISが提供する空間集約関数です。<code>sum</code>や<code>av"
+"erage</code>といった他のSQL集約関数のように使います。"
 #. Tag: sect1
 #, no-c-format
 msgid "&list_aggregates;"
-msgstr ""
+msgstr "&list_aggregates;"
 #. Tag: title
 #: postgis_special.xml:12
 #, no-c-format
 msgid "PostGIS Window Functions"
-msgstr ""
+msgstr "PostGISウィンドウ関数"
 #. Tag: para
 #: postgis_special.xml:13
@@ -57,18 +62,21 @@ msgid ""
 "code>, and <code>lag()</code>. They must be followed by an <code>OVER()</"
 "code> clause."
 msgstr ""
+"次に示す関数は、PostGISが提供する空間ウィンドウ関数です。<code>row_number()</"
+"code>, <code>lead()</code>, <code>lag()</code>等のような他のSQLウィンドウ関数"
+"のように使います。全ての関数で、SQLの<code>OVER()</code>句が必要です。"
 #. Tag: sect1
 #, no-c-format
 msgid "&list_window_functions;"
-msgstr ""
+msgstr "&list_window_functions;"
 #. Tag: title
 #: postgis_special.xml:18
 #, no-c-format
 msgid "PostGIS SQL-MM Compliant Functions"
-msgstr ""
+msgstr "PostGIS SQL-MM準拠関数"
 #. Tag: para
 #: postgis_special.xml:19
@@ -76,19 +84,19 @@ msgstr ""
 msgid ""
 "The functions given below are PostGIS functions that conform to the SQL/MM 3 "
 "standard"
-msgstr ""
+msgstr "次に示す関数は、SQL/MM 3標準に準拠したPostGIS関数です。"
 #. Tag: sect1
 #, no-c-format
 msgid "&list_sqlmm_functions;"
-msgstr ""
+msgstr "&list_sqlmm_functions;"
 #. Tag: title
 #: postgis_special.xml:24
 #, no-c-format
 msgid "PostGIS Geography Support Functions"
-msgstr ""
+msgstr "PostGISジオグラフィ対応関数"
 #. Tag: para
 #: postgis_special.xml:25
@@ -98,6 +106,8 @@ msgid ""
 "take as input or return as output a <link "
 "linkend=\"PostGIS_Geography\">geography</link> data type object."
 msgstr ""
+"次に示す関数と演算子は、<link linkend=\"PostGIS_Geography\""
+">ジオグラフィ</link>データ型を入力または出力に取るPostGIS関数/演算子です。"
 #. Tag: para
 #: postgis_special.xml:27
@@ -110,18 +120,23 @@ msgid ""
 "transform - (favoring UTM, Lambert Azimuthal (North/South), and falling back "
 "on mercator in worst case scenario)"
 msgstr ""
+"(T)の付いた関数はネイティブなジオグラフィ関数ではなく、実行時にST_Transformを"
+"使ってジオメトリとの変換を行います。結果として、日付変更線や極を超えたり、ひ"
+"とつのUTMゾーンではカバーできない巨大なジオメトリを使用する場合に、予期しない"
+"挙動になることがあります。基本的な変換としては、UTMが望ましいですが、ランベル"
+"ト正積方位図法(北/南)、最悪のシナリオでメルカトルに頼ります。"
 #. Tag: sect1
 #: postgis_special.xml:28
 #, no-c-format
 msgid "&list_geography_functions;"
-msgstr ""
+msgstr "&list_geography_functions;"
 #. Tag: title
 #: postgis_special.xml:34
 #, no-c-format
 msgid "PostGIS Raster Support Functions"
-msgstr ""
+msgstr "PostGISラスタ機能関数"
 #. Tag: para
 #: postgis_special.xml:35
@@ -131,18 +146,20 @@ msgid ""
 "take as input or return as output a <xref linkend=\"raster\"/> data type "
 "object. Listed in alphabetical order."
 msgstr ""
+"次に示す関数と演算子は、<xref linkend=\"raster\"/>データ型を入力または出力に"
+"取るPostGIS関数/演算子です。アルファベット順に示します。"
 #. Tag: sect1
 #: postgis_special.xml:36
 #, no-c-format
 msgid "&list_raster_functions;"
-msgstr ""
+msgstr "&list_raster_functions;"
 #. Tag: title
 #: postgis_special.xml:41
 #, no-c-format
 msgid "PostGIS Geometry / Geography / Raster Dump Functions"
-msgstr ""
+msgstr "PostGISジオメトリ/ジオグラフィ/ラスタのダンプ関数"
 #. Tag: para
 #: postgis_special.xml:42
@@ -152,18 +169,21 @@ msgid ""
 "as output a set of or single <link linkend=\"geometry_dump\">geometry_dump</"
 "link> or <link linkend=\"geomval\">geomval</link> data type object."
 msgstr ""
+"次に示す関数は、<link linkend=\"geometry_dump\">geometry_dump</"
+"link>または<link linkend=\"geomval\">geomval</link>データ型の集合または単一デ"
+"ータを入力または出力に取るPostGIS関数です。"
 #. Tag: sect1
 #, no-c-format
 msgid "&list_dump_functions;"
-msgstr ""
+msgstr "&list_dump_functions;"
 #. Tag: title
 #: postgis_special.xml:47
 #, no-c-format
 msgid "PostGIS Box Functions"
-msgstr ""
+msgstr "PostGISボックス関数"
 #. Tag: para
 #: postgis_special.xml:48
@@ -174,18 +194,21 @@ msgid ""
 "consists of <link linkend=\"box2d_type\">box2d</link>, and <link "
 "linkend=\"box3d_type\">box3d</link>"
 msgstr ""
+"次に示す関数は、PostGIS空間型のbox系の型を入力または出力に取るPostGIS関数です"
+"。ボックス系には<link linkend=\"box2d_type\">box2d</link>と<link linkend="
+"\"box3d_type\">box3d</link>があります。"
 #. Tag: sect1
 #: postgis_special.xml:49
 #, no-c-format
 msgid "&list_box_functions;"
-msgstr ""
+msgstr "&list_box_functions;"
 #. Tag: title
 #: postgis_special.xml:54
 #, no-c-format
 msgid "PostGIS Functions that support 3D"
-msgstr ""
+msgstr "3次元対応PostGIS関数"
 #. Tag: para
 #: postgis_special.xml:55
@@ -193,19 +216,19 @@ msgstr ""
 msgid ""
 "The functions given below are PostGIS functions that do not throw away the Z-"
 "Index."
-msgstr ""
+msgstr "次に示す関数は、Zインデクスを放り出さないPostGIS関数です。"
 #. Tag: sect1
 #, no-c-format
 msgid "&list_3d_functions;"
-msgstr ""
+msgstr "&list_3d_functions;"
 #. Tag: title
 #: postgis_special.xml:60
 #, no-c-format
 msgid "PostGIS Curved Geometry Support Functions"
-msgstr ""
+msgstr "PostGIS曲線ジオメトリ対応関数"
 #. Tag: para
 #: postgis_special.xml:61
@@ -213,19 +236,20 @@ msgstr ""
 msgid ""
 "The functions given below are PostGIS functions that can use CIRCULARSTRING, "
 "CURVEPOLYGON, and other curved geometry types"
-msgstr ""
+msgstr "次に示す関数は、CIRCULARSTRING, "
+"CURVEDPOLYGON等の曲線ジオメトリ型が使えるPostGIS関数です。"
 #. Tag: sect1
 #, no-c-format
 msgid "&list_curved_geometry_functions;"
-msgstr ""
+msgstr "&list_curved_geometry_functions;"
 #. Tag: title
 #: postgis_special.xml:66
 #, no-c-format
 msgid "PostGIS Polyhedral Surface Support Functions"
-msgstr ""
+msgstr "PostGIS多面体サーフェス対応関数"
 #. Tag: para
 #: postgis_special.xml:67
@@ -233,19 +257,20 @@ msgstr ""
 msgid ""
 "The functions given below are PostGIS functions that can use "
 "POLYHEDRALSURFACE, POLYHEDRALSURFACEM geometries"
-msgstr ""
+msgstr "次に示す関数は、POLYHEDRALSURFACE, "
+"POLYHEDRALSURFACEMジオメトリが使えるPostGIS関数です。"
 #. Tag: sect1
 #, no-c-format
 msgid "&list_polyhedral_geometry_functions;"
-msgstr ""
+msgstr "&list_polyhedral_geometry_functions;"
 #. Tag: title
 #: postgis_special.xml:72
 #, no-c-format
 msgid "PostGIS Function Support Matrix"
-msgstr ""
+msgstr "PostGIS関数対応マトリクス"
 #. Tag: para
 #: postgis_special.xml:73
@@ -255,6 +280,8 @@ msgid ""
 "and the kinds of spatial types they work with or OGC/SQL compliance they try "
 "to conform to."
 msgstr ""
+"次に示す表は、アルファベット順に並べたPostGIS空間関数と、動作する空間タイプの"
+"種類、対応しようとしているOGC/SQL準拠を示しています。"
 #. Tag: simpara
 #: postgis_special.xml:78
@@ -264,6 +291,9 @@ msgid ""
 "matrix_checkmark.png\"/></imageobject></inlinemediaobject> means the "
 "function works with the type or subtype natively."
 msgstr ""
+"<inlinemediaobject><imageobject><imagedata fileref=\"images/matrix_checkmark."
+"png\"/></imageobject></inlinemediaobject>は、ネイティブで、その型と派生型とに"
+"対応しています。"
 #. Tag: simpara
 #: postgis_special.xml:81
@@ -275,6 +305,11 @@ msgid ""
 "\"best srid\" spatial ref and then cast back. Results may not be as expected "
 "for large areas or areas at poles and may accumulate floating point junk."
 msgstr ""
+"<inlinemediaobject><imageobject><imagedata fileref=\"images/matrix_transform."
+"png\"/></imageobject></inlinemediaobject>は、動作しますが、ジオメトリにキャス"
+"トして「最善のSRID」に投影変換したうえでジオグラフィに戻す、組み込み変換キャ"
+"ストを使います。大きな面積の領域や、極にある領域については、予期しない結果に"
+"なることがありますし、浮動小数点数のごみを蓄積することがあります。"
 #. Tag: simpara
 #: postgis_special.xml:85
@@ -285,6 +320,9 @@ msgid ""
 "works with the type because of a auto-cast to another such as to box3d "
 "rather than direct type support."
 msgstr ""
+"<inlinemediaobject><imageobject><imagedata fileref=\"images/matrix_autocast."
+"png\"/></imageobject></inlinemediaobject>は、直接的な対応でなくbox3dへの変換"
+"といった他からの自動キャストで動作します。"
 #. Tag: simpara
 #: postgis_special.xml:88
@@ -294,6 +332,9 @@ msgid ""
 "matrix_sfcgal_required.png\"/></imageobject></inlinemediaobject> means the "
 "function only available if PostGIS compiled with SFCGAL support."
 msgstr ""
+"<inlinemediaobject><imageobject><imagedata fileref=\"images"
+"/matrix_sfcgal_required.png\"/></imageobject></inlinemediaobject>は、PostGIS"
+"をSFCGAL対応でコンパイルした場合にのみ利用可能な関数です。"
 #. Tag: simpara
 #: postgis_special.xml:91
@@ -304,99 +345,104 @@ msgid ""
 "function support is provided by SFCGAL if PostGIS compiled with SFCGAL "
 "support, otherwise GEOS/built-in support."
 msgstr ""
+"/matrix_sfcgal_enhanced.png\"/></imageobject></inlinemediaobject>は、PostGIS"
+"をSFCGAL対応でコンパイルした場合には、SFCGALが提供し、その他の場合には、GEOS"
+"または組み込み関数で対応します。"
 #. Tag: simpara
 #: postgis_special.xml:94
 #, no-c-format
 msgid "geom - Basic 2D geometry support (x,y)."
-msgstr ""
+msgstr "geom - 基本的な2次元ジオメトリ (x,y)に対応しています。"
 #. Tag: simpara
 #: postgis_special.xml:97
 #, no-c-format
 msgid "geog - Basic 2D geography support (x,y)."
-msgstr ""
+msgstr "geog - 基本的な2次元ジオグラフィ (x,y)に対応しています。"
 #. Tag: simpara
 #: postgis_special.xml:100
 #, no-c-format
 msgid "2.5D - basic 2D geometries in 3 D/4D space (has Z or M coord)."
-msgstr ""
+msgstr "2.5D - 3次元/4次元 "
+"(ZまたはM座標を持つ)空間内の基本的な2次元ジオメトリに対応しています。"
 #. Tag: simpara
 #: postgis_special.xml:103
 #, no-c-format
 msgid "PS - Polyhedral surfaces"
-msgstr ""
+msgstr "PS - 多面体サーフェス (Polyhedral Surface)に対応しています"
 #. Tag: simpara
 #: postgis_special.xml:106
 #, no-c-format
 msgid "T - Triangles and Triangulated Irregular Network surfaces (TIN)"
-msgstr ""
+msgstr "T - 三角形と不規則三角網 (TIN)に対応しています。"
 #. Tag: entry
 #: postgis_special.xml:123
 #, no-c-format
 msgid "Function"
-msgstr ""
+msgstr "関数"
 #. Tag: entry
 #: postgis_special.xml:124
 #, no-c-format
 msgid "geom"
-msgstr ""
+msgstr "geom"
 #. Tag: entry
 #: postgis_special.xml:125
 #, no-c-format
 msgid "geog"
-msgstr ""
+msgstr "geog"
 #. Tag: entry
 #: postgis_special.xml:126
 #, no-c-format
 msgid "2.5D"
-msgstr ""
+msgstr "2.5D"
 #. Tag: entry
 #: postgis_special.xml:127
 #, no-c-format
 msgid "Curves"
-msgstr ""
+msgstr "曲線"
 #. Tag: entry
 #: postgis_special.xml:128
 #, no-c-format
 msgid "SQL MM"
-msgstr ""
+msgstr "SQL MM"
 #. Tag: entry
 #: postgis_special.xml:129
 #, no-c-format
 msgid "<entry>PS</entry>"
-msgstr ""
+msgstr "<entry>PS</entry>"
 #. Tag: entry
 #: postgis_special.xml:130
 #, no-c-format
 msgid "<entry>T</entry>"
-msgstr ""
+msgstr "<entry>T</entry>"
 #. Tag: tgroup
 #: postgis_special.xml:131
 #, no-c-format
 msgid "&table_body_function_support_matrix;"
-msgstr ""
+msgstr "&table_body_function_support_matrix;"
 #. Tag: title
 #: postgis_special.xml:141
 #, no-c-format
 msgid "New, Enhanced or changed PostGIS Functions"
-msgstr ""
+msgstr "新規作成/機能強化/変更されたPostGIS関数"
 #. Tag: sect1
 #, no-c-format
 msgid "&list_new_functions;"
-msgstr ""
+msgstr "&list_new_functions;"
commit 1eefd3e83d3e775a32bc22fcb98af3f78d7611ad
Date:   Thu Jun 29 03:56:44 2023 +0000
    Translated using Weblate (Japanese)
    Currently translated at 100.0% (1611 of 1611 strings)
    Translation: postgis/reference_raster.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_rasterxml/ja/
diff --git a/doc/po/ja/reference_raster.xml.po b/doc/po/ja/reference_raster.xml.po
index dbfce857c..786af3482 100644
--- a/doc/po/ja/reference_raster.xml.po
+++ b/doc/po/ja/reference_raster.xml.po
@@ -8,7 +8,7 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "POT-Creation-Date: 2023-06-22 22:04+0000\n"
-"PO-Revision-Date: 2023-06-27 07:08+0000\n"
 "reference_rasterxml/ja/>\n"
Summary of changes:
 doc/po/ja/postgis_special.xml.po  | 138 +++++++++++++++++++++++++-------------
 doc/po/ja/reference_raster.xml.po |   2 +-
 2 files changed, 93 insertions(+), 47 deletions(-)
hooks/post-receive
