[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1064-gf935a8213
Thu Jun 29 00:08:37 PDT 2023
the project "PostGIS".
       via  f935a8213f11f60dd3fb1a05a40c3eb139fe4881 (commit)
       via  ed061c78c68eaf2182ec15ec1e14a31318759fb6 (commit)
       via  7e27225aae823c8184721284b58b309942cbb421 (commit)
       via  6b870b6c35b35b771b35282d3a5bad9da4896202 (commit)
       via  f4bc98c064cd1346acdd1a9504fc8ac3fd6327f6 (commit)
       via  ba2457eed0c3d965827ab19ab25570df1fb5e17c (commit)
       via  0bfbe0828672efbadf45ca822269605032d05ab5 (commit)
       via  bc0a9c71bb92a6631fc0f6fcc25f9ebb91bc00e9 (commit)
       via  7673f8376726b118deef8351051e0d4ebaca0e79 (commit)
       via  af79c5aeeb22331c8622227c25f1d666d7953706 (commit)
      from  d91d4b4d8655eb7ba7832c09daf57902358233cc (commit)
revisions in full, below.
commit f935a8213f11f60dd3fb1a05a40c3eb139fe4881
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Thu Jun 29 06:17:26 2023 +0000
    Translated tag_P_support using Weblate (Japanese)
    Currently translated at 100.0% (1 of 1 strings)
    Translation: postgis/tag_P_support
    Translate-URL: https://weblate.osgeo.org/projects/postgis/tag_p_support/ja/
diff --git a/doc/po/ja/tag_P_support.xml.po b/doc/po/ja/tag_P_support.xml.po
index 22bdc7a25..bc64d42d5 100644
--- a/doc/po/ja/tag_P_support.xml.po
+++ b/doc/po/ja/tag_P_support.xml.po
@@ -1,22 +1,25 @@
 # Japanese translations for pg package.
 # Automatically generated, 2023.
+# Teramoto Ikuhiro <yellow at affrc.go.jp>, 2023.
 msgid ""
 msgstr ""
 "Project-Id-Version: pg 13\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-06-27 13:24+0000\n"
-"PO-Revision-Date: 2023-06-27 13:24+0000\n"
-"Last-Translator: Automatically generated\n"
-"Language-Team: none\n"
+"PO-Revision-Date: 2023-06-29 07:08+0000\n"
+"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"tag_p_support/ja/>\n"
 "Language: ja\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
+"X-Generator: Weblate 4.16.4\n"
 #. Tag: remark
 #: tag_P_support.xml:5
 #, no-c-format
 msgid "This function supports Polyhedral surfaces."
-msgstr ""
+msgstr "この関数は多面体サーフェスに対応しています。"
commit ed061c78c68eaf2182ec15ec1e14a31318759fb6
Date:   Thu Jun 29 06:03:58 2023 +0000
    Translated tag_index_aware using Weblate (Japanese)
    Translation: postgis/tag_index_aware
    Translate-URL: https://weblate.osgeo.org/projects/postgis/tag_index_aware/ja/
diff --git a/doc/po/ja/tag_index_aware.xml.po b/doc/po/ja/tag_index_aware.xml.po
index 3a66e6043..d359788fc 100644
--- a/doc/po/ja/tag_index_aware.xml.po
+++ b/doc/po/ja/tag_index_aware.xml.po
@@ -1,19 +1,22 @@
 msgid ""
 msgstr ""
+"tag_index_aware/ja/>\n"
 "Language: ja\n"
 #. Tag: remark
 #: tag_index_aware.xml:1
@@ -21,4 +24,5 @@ msgstr ""
 msgid ""
 "This function automatically includes a bounding box comparison that makes "
 "use of any spatial indexes that are available on the geometries."
-msgstr ""
+msgstr "この関数の呼び出しによって、ジオメトリで使用可能なインデックスを使用するバウ"
+"ンディングボックスの比較が自動的に行われます。"
commit 7e27225aae823c8184721284b58b309942cbb421
Date:   Thu Jun 29 06:04:53 2023 +0000
    Translated tag_M_support using Weblate (Japanese)
    Translation: postgis/tag_M_support
    Translate-URL: https://weblate.osgeo.org/projects/postgis/tag_m_support/ja/
diff --git a/doc/po/ja/tag_M_support.xml.po b/doc/po/ja/tag_M_support.xml.po
index 15ba4f495..cc3108c9a 100644
--- a/doc/po/ja/tag_M_support.xml.po
+++ b/doc/po/ja/tag_M_support.xml.po
@@ -1,22 +1,25 @@
 msgid ""
 msgstr ""
+"tag_m_support/ja/>\n"
 "Language: ja\n"
 #. Tag: remark
 #: tag_M_support.xml:5
 #, no-c-format
 msgid "This function supports M coordinates."
-msgstr ""
+msgstr "この関数はM値に対応します。"
commit 6b870b6c35b35b771b35282d3a5bad9da4896202
Date:   Thu Jun 29 05:57:25 2023 +0000
    Translated tag_address_standardizer_required using Weblate (Japanese)
    Translation: postgis/tag_address_standardizer_required
    Translate-URL: https://weblate.osgeo.org/projects/postgis/tag_address_standardizer_required/ja/
diff --git a/doc/po/ja/tag_address_standardizer_required.xml.po b/doc/po/ja/tag_address_standardizer_required.xml.po
index c91bd9976..b57693dda 100644
--- a/doc/po/ja/tag_address_standardizer_required.xml.po
+++ b/doc/po/ja/tag_address_standardizer_required.xml.po
@@ -1,22 +1,25 @@
 msgid ""
 msgstr ""
+"tag_address_standardizer_required/ja/>\n"
 "Language: ja\n"
 #. Tag: remark
 #: tag_address_standardizer_required.xml:5
 #, no-c-format
 msgid "This method needs address_standardizer extension."
-msgstr ""
+msgstr "このメソッドはaddress_standardizerエクステンションが必要です。"
commit f4bc98c064cd1346acdd1a9504fc8ac3fd6327f6
Date:   Thu Jun 29 06:21:51 2023 +0000
    Translated tag_T_support using Weblate (Japanese)
    Translation: postgis/tag_T_support
    Translate-URL: https://weblate.osgeo.org/projects/postgis/tag_t_support/ja/
diff --git a/doc/po/ja/tag_T_support.xml.po b/doc/po/ja/tag_T_support.xml.po
index 5c722d422..59b7e8751 100644
--- a/doc/po/ja/tag_T_support.xml.po
+++ b/doc/po/ja/tag_T_support.xml.po
@@ -1,19 +1,22 @@
 msgid ""
 msgstr ""
+"tag_t_support/ja/>\n"
 "Language: ja\n"
 #. Tag: remark
 #: tag_T_support.xml:5
@@ -21,4 +24,4 @@ msgstr ""
 msgid ""
 "This function supports Triangles and Triangulated Irregular Network Surfaces "
 "(TIN)."
-msgstr ""
+msgstr "この関数は三角形と不規則三角網 (TIN)に対応しています。"
commit ba2457eed0c3d965827ab19ab25570df1fb5e17c
Date:   Thu Jun 29 06:19:14 2023 +0000
    Translated tag_sfcgal_required using Weblate (Japanese)
    Translation: postgis/tag_sfcgal_required
    Translate-URL: https://weblate.osgeo.org/projects/postgis/tag_sfcgal_required/ja/
diff --git a/doc/po/ja/tag_sfcgal_required.xml.po b/doc/po/ja/tag_sfcgal_required.xml.po
index 999b4603a..304be0d3a 100644
--- a/doc/po/ja/tag_sfcgal_required.xml.po
+++ b/doc/po/ja/tag_sfcgal_required.xml.po
@@ -1,22 +1,25 @@
 msgid ""
 msgstr ""
+"tag_sfcgal_required/ja/>\n"
 "Language: ja\n"
 #. Tag: remark
 #: tag_sfcgal_required.xml:5
 #, no-c-format
 msgid "This method needs SFCGAL backend."
-msgstr ""
+msgstr "このメソッドにはSFCGALバックエンドが必要です。"
commit 0bfbe0828672efbadf45ca822269605032d05ab5
Date:   Thu Jun 29 06:22:48 2023 +0000
    Translated tag_Z_support using Weblate (Japanese)
    Translation: postgis/tag_Z_support
    Translate-URL: https://weblate.osgeo.org/projects/postgis/tag_z_support/ja/
diff --git a/doc/po/ja/tag_Z_support.xml.po b/doc/po/ja/tag_Z_support.xml.po
index a29a44277..d6bd47cac 100644
--- a/doc/po/ja/tag_Z_support.xml.po
+++ b/doc/po/ja/tag_Z_support.xml.po
@@ -1,22 +1,25 @@
 msgid ""
 msgstr ""
+"tag_z_support/ja/>\n"
 "Language: ja\n"
 #. Tag: remark
 #: tag_Z_support.xml:5
 #, no-c-format
 msgid "This function supports 3d and will not drop the z-index."
-msgstr ""
+msgstr "この関数は3次元に対応し、Z値を削除しません。"
commit bc0a9c71bb92a6631fc0f6fcc25f9ebb91bc00e9
Date:   Thu Jun 29 06:21:09 2023 +0000
    Translated tag_sqlmm_compliant using Weblate (Japanese)
    Translation: postgis/tag_sqlmm_compliant
    Translate-URL: https://weblate.osgeo.org/projects/postgis/tag_sqlmm_compliant/ja/
diff --git a/doc/po/ja/tag_sqlmm_compliant.xml.po b/doc/po/ja/tag_sqlmm_compliant.xml.po
index 064420ec2..916c4e770 100644
--- a/doc/po/ja/tag_sqlmm_compliant.xml.po
+++ b/doc/po/ja/tag_sqlmm_compliant.xml.po
@@ -1,22 +1,25 @@
 msgid ""
 msgstr ""
 "POT-Creation-Date: 2023-06-27 13:11+0000\n"
-"PO-Revision-Date: 2023-06-26 16:31+0000\n"
+"tag_sqlmm_compliant/ja/>\n"
 "Language: ja\n"
 #. Tag: remark
 #: tag_sqlmm_compliant.xml:5
 #, no-c-format
 msgid "This method implements the SQL/MM specification."
-msgstr ""
+msgstr "このメソッドはSQL/MM仕様の実装です。"
commit 7673f8376726b118deef8351051e0d4ebaca0e79
Date:   Thu Jun 29 06:24:07 2023 +0000
    Translated tag_sfs_compliant using Weblate (Japanese)
    Translation: postgis/tag_sfs_compliant
    Translate-URL: https://weblate.osgeo.org/projects/postgis/tag_sfs_compliant/ja/
diff --git a/doc/po/ja/tag_sfs_compliant.xml.po b/doc/po/ja/tag_sfs_compliant.xml.po
index cf73306e2..c03d70841 100644
--- a/doc/po/ja/tag_sfs_compliant.xml.po
+++ b/doc/po/ja/tag_sfs_compliant.xml.po
@@ -1,19 +1,22 @@
 msgid ""
 msgstr ""
+"tag_sfs_compliant/ja/>\n"
 "Language: ja\n"
 #. Tag: remark
 #: tag_sfs_compliant.xml:3
@@ -23,3 +26,5 @@ msgid ""
 "standards/sfs\">OGC Simple Features Implementation Specification for SQL 1.1."
 "</ulink>"
 msgstr ""
+"このメソッドは<ulink url=\"http://www.opengeospatial.org/standards/sfs\">OGC "
+"Simple Features Implementation Specification for SQL 1.1.</ulink>の実装です。"
commit af79c5aeeb22331c8622227c25f1d666d7953706
Date:   Thu Jun 29 06:18:25 2023 +0000
    Translated tag_sfcgal_enhanced using Weblate (Japanese)
    Translation: postgis/tag_sfcgal_enhanced
    Translate-URL: https://weblate.osgeo.org/projects/postgis/tag_sfcgal_enhanced/ja/
diff --git a/doc/po/ja/tag_sfcgal_enhanced.xml.po b/doc/po/ja/tag_sfcgal_enhanced.xml.po
index 180b74f88..8367ee96b 100644
--- a/doc/po/ja/tag_sfcgal_enhanced.xml.po
+++ b/doc/po/ja/tag_sfcgal_enhanced.xml.po
@@ -1,22 +1,25 @@
 msgid ""
 msgstr ""
+"tag_sfcgal_enhanced/ja/>\n"
 "Language: ja\n"
 #. Tag: remark
 #: tag_sfcgal_enhanced.xml:3
 #, no-c-format
 msgid "This method is also provided by SFCGAL backend."
-msgstr ""
+msgstr "このメソッドはSFCGALバックエンドでも提供されます。"
Summary of changes:
 doc/po/ja/tag_M_support.xml.po                     | 11 +++++++----
 doc/po/ja/tag_P_support.xml.po                     | 11 +++++++----
 doc/po/ja/tag_T_support.xml.po                     | 11 +++++++----
 doc/po/ja/tag_Z_support.xml.po                     | 11 +++++++----
 doc/po/ja/tag_address_standardizer_required.xml.po | 11 +++++++----
 doc/po/ja/tag_index_aware.xml.po                   | 12 ++++++++----
 doc/po/ja/tag_sfcgal_enhanced.xml.po               | 11 +++++++----
 doc/po/ja/tag_sfcgal_required.xml.po               | 11 +++++++----
 doc/po/ja/tag_sfs_compliant.xml.po                 | 11 ++++++++---
 doc/po/ja/tag_sqlmm_compliant.xml.po               | 11 +++++++----
 10 files changed, 72 insertions(+), 39 deletions(-)
hooks/post-receive
