[postgis-tickets] [PostGIS] #5418: Don't know what gentext to create for xref to: "listitem" (linkend=tiger_geocoder_loading_data)
PostGIS trac at osgeo.org
Thu Jun 29 14:16:08 PDT 2023
  Reporter:  strk           |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  medium         |  Milestone:  PostGIS 3.4.0
 Component:  documentation  |    Version:  master
Resolution:  fixed          |   Keywords:
Comment (by strk):
 For the record: the error in the subject is not the cause of PDF build
 failure, as it ALSO happens in the 3.2 branch without preventing a
 successful build of the pdf:
 Don't know what gentext to create for xref to: "qandaentry"
 (linkend=legacy_faq)
 'postgis-3.2.6dev.pdf' successfully built
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5418#comment:4>
